bg99
posted on 13/10/08 at 02:31 PM |
Help!! - Zetec Thermostat info needed
Hi
I could do with some help if anyone can!!
I need to know the hole positions for the 3 bolts that hold the thermostat housing onto a zetec head.
I am away from home at the moment (and my car!!) and need to get an adaptor plate made but I could do with these dims.
Also and this is from memory, I think there is a rubber seal that fits into the plastic housing if anyone knows the diameter of this and the dims of
the groove it fits into it would really really help!!!!
Cheffy
posted on 13/10/08 at 04:49 PM |
Hi bg99,
Dimensions as requested - approx distance between hole centres.
Top left to bottom centre hole (1) 66.76mm
Top left to top right hole (2) 59.48mm
Top right to bottom centre (3) 76.51mm
The channel for the rubber seal its approx 6.75mm wide and measures 49.5mm internally and 56.22mm externally.
Hope that helps,
Mart.
[img][/img]
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
