Whos going or planning to on October
Newlands?
Bought ball joints etc; will need advice on
wishbones.
Pcd on ford axles springs to mind.
Trueblue
Should be!
Yeah, about time i got out !! he he
Jason
Yeh, perhaps i'll be able to make this one... tho i'm in Newcastle from the Sat 2nd
so maybe i'll make a walton at end of october
Should be there.
Trueblue,
Wishbones are pretty simple to do. But don't do them before you've done the chassis. The wishbones are too 'mission critical' to
risk making before you've had the welding practice of making the chassis.
Just make a *decent* jig out of MDF and remember to get the castor correct on the top/front wishbones (it's wrong in The Book). If you're
using Cortina uprights I believe it's 22mm, if Sierra then it's 25mm but I'm only half remembering those figures.
Also, see the post by Bass on the following link:
http://www.locostbuilders.co.uk/viewthread.php?tid=2080
it's a good idea and worked well for me.
As for PCD of Ford hubs- it's 108mm.
HTH,
James
EDIT: Changed PCD to avoid confusion- cheers Ned!
[Edited on 21/9/04 by James]
James, check your figures i think ford pcd is 108
I'll have just arrived in rhodes, so no chance of making it to newlands, sorry guys
James, if I give you the money, can you get my indicators of jason if he's there?
cheers,
Ned.
Should be there too....
And Hicost - have a great time you git
Hicost
Can you get online over there,would be nice to know how your getting on and what the misserable old buggers are up too.
is it the Saturday 2nd or sunday 3rd?
what time? 10ish as per http://www.locostbuilders.co.uk/viewthread.php?tid=15900
Hi ya, It's always the first Sunday of the month, the eager ones get there anytime after 9 ish, as there's not usually a queue for the
tea's then
Although time is dependant on the weather
Jason
Originally posted by ned
James, check your figures i think ford pcd is 108![]()
I'll have just arrived in rhodes, so no chance of making it to newlands, sorry guys![]()
cheers,
Ned.
Got my first IAM observed run on the 3rd. Will see you une autre fois.
Why do car clubs have to meet on the first Sunday of the month? Both MR2DC and IAM (if you can call it a car club) do!
Why do car clubs have to meet on the first Sunday of the month? Both MR2DC and IAM (if you can call it a car club) do!![]()
Fair e'nuf!
Will have to talk nicely to my IAM observer and see if we can re-arrange. (Yeah right!)
we normally meet at walton bridge the other sundays,its the only time i get a decent meal
Hi James thanks for the pointers in making
the wishbones.
What prompted my question on the ford pcd was I compared my fiesta wheels;
13" with the escort back end , seemed to be no great shakes there.
However as I checked the holes in said wheel with front hubs that just happened to be sierra;they did not appear to be compatible.
Will bring my sierra hub to compare against a wheel just in case I've missed something.
Trueblue
My mk1 Escort back end and sierra front hubs have the same wheel bolt alignment. Cant imagine how yours are different ??
the offset (hub flange to wheel centreline) may be different between escort and sierra, i can't remember though.
Ned.
I think the ONE of the problems here is the fiesta wheels,i fear they have to go steve.
How can you say that Bob???! I'm shocked at you!
I mean, some 1983 13" 1.0 Fiesta steels will look effing brilliant!
Ditch 'em Steve!
James
I should be there (if i'm still allowed
Yes, most likely be the offset... Front wheel drive wheels are no good on a rear wheel drive car ! Get some Sierra wheels if you want to be really
cheap.. cough, sorry want to be really locost
I was trying to be really locost (TIGHT like scrooge) in using what i had.
however i will still bring the hubs along as
i am curious just to see if my sandblasting and painting has made any difference to the fit.
This is all getting rather exciting; maybe its another excuse to junk some other bits.
Clear garage approaching faster.!!!
Might even get around to having a play with the welder.
If i can start this side of xmas before there are other distractions.
See you all sinday, should be sunday
depends whats about.
Trueblue
THATS IT,not going.
I fear i may need sectioning
After a cup of coffee and some counciling at walton mountain i have relented
Any time Bob!
See ya Sunday!
fozzie
Originally posted by bob
After a cup of coffee and some counciling at walton mountain i have relented![]()
The Sierra wheels with the large holes could look pretty cool , I was going to use them but the offsets where wrong.
Also (contraversially) steel wheels are often lighter than (lightweight) alloy ones!!
Could be a good thread , put together a database of wheel weights............................
Plus they can stand up to being bumped up and down curbs lol (women take note!!!)
Dave,
Pardon my enquiry but how are the offsets wrong?
I will be using sierra wheels now; have to speak to Ben,
Will bring half shaft along to compare as Im getting confused here!
Trueblue
if halfshafts confuse you (they fit in the axle casing
) just think how bad it'll be if you ever start welding up the chassis, think fu1+2 guys
Ned.
The Sierra wheels have there main offset to the inside ,so on a book chassis with an Escort axle they will rub on the chassis without spacers.
Typical wider Escort mk2 wheels have the larger offset to the outside.
I know this 'cos I had a set off Sierra steel wheels on my car while I was building it........
'Pepper pots' also have the offset towards the axle and therefore rub on the trailing arms RS Alloys are correct tho !!
Jason
What luck!! My room mate @ Bradfield lives walking distance from Newlands Corner. I'll have to stay over at his house one weekend when you are there!
Hmmm, greasy egg and bacon bap!
I'm already moist with anticipation!
Seeya there,
James
Have a feeling we might all get a bit moist actually- BBC Weather says it gonna rain.
Do we wanna go someplace else instead- like over the road?
James
Heard the same thing about the weather, i think hicost must be driving through it now !!
over the road sounds better, (or box hill !) but
doesn't it open alot later ?
Jason
Let's just say normal place unless it's raining- then over the road.
Box Hill will be open but I don't think we should change location now. There's too much possibility of people planning to come not checking
here first.
James
box hill opens at 9 i think,every chance we will visit the hill nov/dec/jan as we did before.
I'm doubtfull for sunday morn now as i'm picking up some ali for a boot box,this 9i feel is more important than having to suffer you ugly
lot and stupid questions (thats apart from james who owes me a tenner)
I'm doubtfull for sunday morn now as i'm picking up some ali for a boot box,this 9i feel is more important than having to suffer you ugly lot and stupid questions (thats apart from james who owes me a tenner)![]()
No councelling needed,it was phone conversation i had with an old mate from up north that did it.
I forgot that once on the road i should be making all the peeps who havnt finished there cars HAVE IT
large style LOL
The place 'across the road', is it a proper brekie place or just 'tea and coffee' ??
Jason
I forgot that once on the road i should be making all the peeps who havnt finished there cars HAVE ITlarge style LOL
Houston - I have pedals again ,will be there if not pithing down.
Bob - How long is a piece of string?
Bob - Is the pope catholic?
Bob - Is Bernie Ecclestone a greedy little git?
Bob - Is an Indy a kit car?
Bob - Have you got a screen yet?
Bob - Whats the time?
Bob - Do you think I'm ugly?
DAVE is that a polo rad ?
No you are not ugly but i'm not that way inclined,yet
NO! Bob please take another look I really am pretty ****ing ugly!!!
Dave
I've seen worse mate,trouble is it would get me in trouble if i siad where
Originally posted by Deckman001
The place 'across the road', is it a proper brekie place or just 'tea and coffee' ??![]()
Jason
Oooooops, got back late from Germany last nite and completely forgot about this mornings meet - but as it's p*ssing down I'm rather glad!
Here's the October meet at Newlands corner ,there was briefly a nice Luego Velocity also in attendance..........................
None of the " you dont need weather equipment" mob arrived
Whats donut doing there,i thought we had blackballed him
There were so many cops there they took away the barricades we'd put up for him!
See, I said at the time the avatar got put up (by ChrisW) my hair doesn't look like that normally:
Instead, now it looks like I've joined the paras!
Hope you enjoyed the ride Jason! (And the one in Dave's car).
Seeya,
James
(still freezing!)
P.S. Where the hell's Conrod? First time I've known him to miss a brekkie?
[Edited on 3/10/04 by James]
i have a car not a boat,thats why i didnt turn up
Thanks for all the advice on offsets etc.
Glad I got that cleared up, I had visions of
two different wheel types to accomodate the axle sets I ended up with.
Another question!
What types of steering racks are more widely available?
Presumably escort types will disappear soon; I'm trying to use more withit components to update the design.
Trueblue
None of the " you dont need weather equipment" mob arrived:
I didn't turn up, coz I never said I was going in t'first place!
I didnt turn up because i dont like anybody except james cos he owes me a tenner
Daves polo rad is nice though
You know the only reason you didn't turn up, is cos i couldn't be there
yes ben thats the reason
Bob,
I'm surprised you didn't come just to see lovely Dave's lovely radiator- it's lovely!
No - Bob this is what you missed my luverly new pedal box cover and bulkhead extension..
[Edited on 4/10/04 by Surrey Dave]
A big thanks to Dave for the lift back to redhill, was very enlightning and enjoyable even in the rain
Jason
Enlightening ? or frightening?...........
No - Bob this is what you missed my luverly new pedal box cover and bulkhead extension..![]()
Thanks James
I'll have a wander up blackbushe and see
what they got.
Someone told me there is a Ford place over near Bracknell that has all sorts of classic items; now wheres my A-Z?
Trueblue
Why does it look like i'm scratching my balls???? Probably because i am!!
P.S. You wait till you see what i turn up in in a few months!!!!
You may well turn up in it,but we will be rolling up watching you get out of it
I saw a good mini last week,it made of leather and wrapped round a an old brass.
LOL
Going back to my roots there,i missed out the word "was"thought i was going bodmin
Well here is a pic of my recently painted mini. It's still in the paintshop in this pic but is in my garage at home right now waiting to be put
back together. It will look better when it's finished!
Incidently the colour scheme is the Gulf Oils racing scheme.
[Edited on 6/10/04 by donut]
hey judas you turncoat
I remember when there was an indy in your garage.
anyway whos going to put that pile of filler back together ?
Nice one Andy mate!
fozzie
ps: just lurve the Gulf colours
Bob: You're such a cheeky bugger!!! You're turning into one of those 'grumpy old men'!!
and it's ME ME ME who is
going to put that peice of british craftsmanship back together.......with a little help from a friend
Fozzie: Thank you! Nice to see someone apreciates a good thing when they see it
We must be two of a kind!!
This is the self preservation society!
Saw a programme about a new theatre show last night. it was Shakespeare performed with 3 Mini's forming all the props and scenery...........
How Bizzare!!!
or was that the self persevering society
Saw a programme about a new theatre show last night. it was Shakespeare performed with 3 Mini's forming all the props and scenery...........![]()
Fo ned, gave young james those indicators, but he didn't have the dosh , so you need to pay me not him !!
See ya next meet
What indicators?
James
Jason
No, definately can't remember you giving me any indicators for Ned.
There certainly isn't a pair of rather nice looking Ducati indicators anywhere near me that are for Ned.
James
James, I'll be round with the heavies
Jason, I owe you some mullah! I can post a cheque if you want to u2u me details..
Ned.
james is going to be skint when we all catch up with him
Too late!
Why do you think I'm building a car for 250quid!
James
