Steel Floor
Bigheppy - 16/11/08 at 03:44 PM
On my last rebuild of my magenta I installed a flat steel floor, nice and strong but it flexes and makes 'BOING' noises. So my new project has a very strong steel floor that does not flex and cost me nothing. How you may ask, please ask, well I had been thinking how to press a sheet as found on production cars. I then noticed that a central heating radiator looked ideal and began the hunt. While driving in Hull I found one dumped on a roundabout so picked it up and took it home. A section was cut from it to weld into the chassis but it weighed too much, so after drilling out 123 spot welds and separating the front and back panels I was left with a perfect panel, now welded to the chassis i'm well pleased. So if you want a strong floor look out for old radiators, a modern one is much thinner gauge steel so it wont need the front and rear panels separating.
Have a look in my archive under steel floor
[Edited on 16/11/08 by Bigheppy]
speedyxjs - 16/11/08 at 03:46 PM
Piccys please
Ben_Copeland - 16/11/08 at 03:49 PM
Can you still run hot water through it and keep your arse warm ???
jacko - 16/11/08 at 03:55 PM
So thats were my rad went
bloody fly tipping in Hull is getting worse
Come on we need photos
Jacko
ravingfool - 16/11/08 at 03:57 PM
excellent, locost seat warmer, just connect it up to the coolant system through a thermostat
Dangle_kt - 16/11/08 at 04:08 PM
[img][/img]
ballcock - 16/11/08 at 04:09 PM
Can't you just put some bends in a flat sheet every couple of inches (25.4mms to the metricated) must be lighter than a radiator, those steel panels are still heavy even the newer ones.
MikeR - 16/11/08 at 04:13 PM
errm, a couple of inches would be 50.8mm :p
Bigheppy - 16/11/08 at 04:15 PM
The front and the rear of the panel were separated and only one side used, the steel on mine is approx .6mm thick the same as I would have used to bend a panel.
ballcock - 16/11/08 at 04:20 PM
Looks good, if you haven't got a sheet bender it's a worthwhile idea.
coozer - 16/11/08 at 05:32 PM
Genuine forward thinking way to keeping the costs down. Excellent idea to replace the wooden bed of my trailer
