1.6 zetec and type 9 in a ron champion chassis
*davies144* - 25/2/09 at 05:48 PM
hi just wondering if the standard chassis built to the book will be able to acccept a 1.6 zetec se and type 9 gear box? if anyone has used this combination and has some pics would be great to see them, cheers ben
Paul TigerB6 - 25/2/09 at 06:05 PM
Zetec SE - like this one?
Should be a very easy fit - plenty have fitted bigger engines. Nice choice of engine btw
[Edited on 25/2/09 by Paul TigerB6]
*davies144* - 25/2/09 at 06:24 PM
that the one doesnt quite look like yet though!!! so do you think the gearbox will fit without alteration needed to the chassis
?? ben
Paul TigerB6 - 25/2/09 at 06:26 PM
The type 9 isnt very wide at all so cant see it being an issue. I'm sure someone will confirm specifically for the Ron Champion chassis shortly.
The Baron - 25/2/09 at 06:48 PM
I dont think the Type 9 will fit in a standard Book chassis, easily fixed with a angle grinder and re-welded.
B
Gazeddy - 25/2/09 at 06:54 PM
which zetec? escort or focus
escort one will bolt to a t9 but why not go 2litre and rs1800 cams.
focus one will need a new bellhousing as the bolt pattern is different
[Edited on 25/2/09 by Gazeddy]
*davies144* - 25/2/09 at 07:00 PM
it came from a 2000 fiesta zetec s, well i thort id go for a smaller engine because i am only 20 so my insurance will be bad enough with a 1.6!!!
Paul TigerB6 - 25/2/09 at 07:02 PM
Have you already got the chassis then??
*davies144* - 25/2/09 at 07:08 PM
yeh bought the chassis a couple of weeks back
Paul TigerB6 - 25/2/09 at 07:10 PM
might be worth measuring across the transmission tunnel then and popping the numbers up. No doubt someone will have a type 9 who can measure the width behind the bell housing
UncleFista - 25/2/09 at 07:15 PM
I can confirm a type9 fits in a standard Champion "book" chassis quite easily.
It's the Zetec[1] that's a tight fit
[1] Silvertop, not small...
Gazeddy - 25/2/09 at 07:20 PM
its a blacktop. which is smaller but doesnt fit the type 9 box without a new bellhousing
Mix - 25/2/09 at 07:20 PM
Hi
Type nine isn't too big a problem. The engine however is taller and ideally requires the chassis sides to be raised an inch.
Regards Mick
*davies144* - 25/2/09 at 07:24 PM
good stuff about the gearbox, what engine would you go for as a cheap to insure car, 1.6 cvh???
Paul TigerB6 - 25/2/09 at 07:25 PM
The all alloy Zetec SE is a much smaller engine though - more like the Toyota 4-age in size than the taller 1.8 / 2.0 Zetec's. The bellhousing is on Shawspeed's website linked to earlier - just not so sure they are still trading. There is another company doing stuff for the Zetec SE isnt there??
Try a search for info - i know i have seen someone on here with this engine
Paul TigerB6 - 25/2/09 at 07:29 PM
You will be looking at a specialist policy and you might well find the engine size doesnt actually make that much difference. Even so, i would rather pay a bit more on insurance for a couple of years and build the car how i want it rather than just to reduce the insurance costs (and it may cost you more in the long run trying to fit a less common engine)
Try a search for insurance for under 25's on here and maybe ask what premiums the under 25's are paying - i'm sure most will happily tell you
Gazeddy - 25/2/09 at 07:32 PM
try 1.4 cvh then you can change to the much nicer and tougher zetec e eventually
my personal opinion. although im think of building a chassis to take a 3.2 5 cyl tdci transit engine.
Daddylonglegs - 26/2/09 at 01:21 PM
Not sure if this'll help?
Type 9
JB
*davies144* - 26/2/09 at 06:44 PM
cheers thanks for the help
David Jenkins - 26/2/09 at 08:13 PM
I have a type 9 box in my standard chassis - it's positioned to that the back face of the bellhousing is about 1cm away from the chassis uprights.
There's a fair bit of room all around in the tunnel.
