Was looking at the front of the chassis making plans on where to cut it to start the rebuild. Looking at the damaged/repaired tubes it looks like the
best place to cut will be just behind the rear lower wishbone mount, where there is a vertical upright between the upper and lower chassis rails. I
can then make a new front end on the bench and join it back onto the chassis when complete. I was thinking the best way to join the main chassis rails
would be to get a solid insert machined that would slide inside the the chassis tubes between the join, then the do the necessary welding. But then
we (well dad) had a thought, why not close off the chopped off front of the main chassis (cross members, triangulation) and have 2 flat plates either
side which then bolt to flat plates on the front section of the chassis (which house all suspension). This would make future suspension damage repairs
easy as i could just build a new front section and bolt it on, i could almost have a spare front end to take to meets incase of an incident.
The car is a fisher fury with lowered race chassis by the way.
Any thoughts?? Any cars out there with a similiar setup?
I think a drawing of what you propose would be a good idea.
Nothing against it, as its similar to the F1 cars with their bolt on rear ends. My main concern would be the bolts being ripped out the brackets
earlier than the original tube would have failed so I think the brackets would have to be quite substantial to be totally safe.
What about alignment?
My gut feeling is you'll be introducing a lot of joints made to locost tolerances, so might end up with some interesting handling quirks.
A very simple mock up (no suspension pick ups and chassis tubes not all shown)
In theory if you make a significant modification to the chassis design during a repair/rebuilt then you'll need to re-IVA the car.
I say in theory because it would be rather difficult for anyone to prove it wasn't like that for the original test.
car isn't road registered, so doesn't matter![]()
I'd say it sounds like a good idea. I was shocked when i first saw how old school F1 chassis were bolted together, they looked as though
they'd fall apart.
How accurate are your building faccilities? You could just have some kind of pin or overlapping brackets to line everything up, making up a jig to
keep future parts the same.
As for strength, it should be fine. Most of the bolts would be in single shear for most of the time. The main problem would be keeping it all rigid as
both sections are losing a lot of their support. Also, there will be a small weight increase.
One advantage would be that you'll be able to test differnt designs, such wishbone lengths and mounting positions and triangulation.
As for strength, it should be fine. Most of the bolts would be in single shear for most of the time. The main problem would be keeping it all rigid as both sections are losing a lot of their support. Also, there will be a small weight increase.
What about steering column ?
Also with all that strengthening at the nose, next shunt you have will simply bend main chassis further back.
RD
RD![]()
Nothing wrong with bolt on subframes - the E-Type is one example where the whole front end from the passenger bulkhead is a bolt on assembly.
The suqareness and alignment will require some careful work, but not beyond locost fabrication.
One thought.....looking at you're model I suspect any front end impact might generate chassis damage further back as the sub-frame itself will be
pretty stiff.
Isn't your degree in this type of stuff? Its a very interesting idea.
Is there a Fury on the RGB grid that is anything like the original anymore?
One thought.....looking at you're model I suspect any front end impact might generate chassis damage further back as the sub-frame itself will be pretty stiff.
Is there a Fury on the RGB grid that is anything like the original anymore?![]()
I like the idea but not the design at all.
Think about the reason a spaceframe is as strong as it is, tubes in compression and tension how they are strongest. Instead of bolting 2 flat plates
together at the joint which will be heavy and I think flex unless it's very thick plate why not join the main tubes by having an insert in one
half that slides up the other and then a bolt through with compression tube? Keeps everything light and strong.
Think about the reason a spaceframe is as strong as it is, tubes in compression and tension how they are strongest. Instead of bolting 2 flat plates together at the joint which will be heavy and I think flex unless it's very thick plate why not join the main tubes by having an insert in one half that slides up the other and then a bolt through with compression tube? Keeps everything light and strong.
Tha looks rather nice!
It also means that the next prang goes into the plate structure, which is also replacable.
