Locost Chassis build diary (in photos) - Pic Heavy! MM Paradigm
Steve Hignett - 29/3/10 at 05:32 PM
obviously it's not finished yet, so I'll be adding some more pics over the next couple weeks! (I've not done much on it in the last fortnight as I've been a tad busy around the house!)
liam.mccaffrey - 29/3/10 at 05:42 PM
Awesome progress mate, did you bend the big tubes? What size were they and how did they go?
speedyxjs - 29/3/10 at 05:45 PM
Holy crap thats alot of photos
Good work there Steve
ps how long did it take you to write that post with all those pics?
iscmatt - 29/3/10 at 05:48 PM
i tell you what i'm glad you resized them to fit the page!!
deanwelch - 29/3/10 at 06:02 PM
well done...............keep it up...............you'll be finished in no time
richardh - 29/3/10 at 06:13 PM
quality work there
dazzx10r - 29/3/10 at 06:35 PM
superb that mate, those side tubes are a bit like my MK Midi. I like the home made garage coming off the fence!
fesycresy - 29/3/10 at 07:10 PM
Bet that tank will leak.
chris mason - 29/3/10 at 07:19 PM
I'd be more concerned about the prop
Good work Steve
McLannahan - 29/3/10 at 07:36 PM
It's all right I suppose?
Pants
Richard Quinn - 29/3/10 at 08:09 PM
Looks cr*p
Dangle_kt - 29/3/10 at 09:12 PM
nice steve - was checking your site every now and then to see if you'd done more - glad work had been going on, on the QT.
Did anyone else do a little mini gasp when they saw that AMAZIN rad and oil cooler?
Just me then....
hicost blade - 29/3/10 at 09:19 PM
That steering column looks familiar, are you thinking of making a ball raced paddle shift on that??
hicost blade - 29/3/10 at 09:22 PM
BTW whats the resonant frequency of teeth??
I hope its not the same as 11,000 rpm on a ZX10
mrwibble - 29/3/10 at 09:46 PM
wow. to me that level of construction is mind boggling.
OX - 29/3/10 at 10:17 PM
Looks like you've found something to to do with all those shopping trolleys you keep borrowing
welderman - 30/3/10 at 08:13 AM
Keep up the good work sparrow, will see you when i get back from my cruise mate, oh and theres a little something in the post for you .
ps look after the mrs and little joe .
Big Joe
kb58 - 30/3/10 at 02:23 PM
Guess I'm the first to rain on the parade.
Will the suspension brackets be reinforced? Welding flat brackets onto round tubes will lead to grief. My brother's Locost had brackets like that, cantilevered off the sides of the tubes, and one wheel broke off because of it. Examining the opposite side showed that bracket was cracked, too, almost all the way through. See pics below... the last one is the most damning - caught in the act of failing! For a round tube chassis it'll fail much quicker.
On the fuel tank, do no rigidly mount it. In any sort of accident the tank must be free to move around on its own. If the chassis gets slightly bent it can rip the mounting tabs out of the tank, leaving a big hole.
[Edited on 3/30/10 by kb58]
TimC - 30/3/10 at 04:13 PM
Gussets aplenty yet to be installed. As for the tank.... well, its a good point but lots of cars have hard mounted tanks and I've seen straps pierce tanks as well....
Oh, Steve reads your stuff Kurt so knows about the bracket issues.
GonzoRacer - 30/3/10 at 11:35 PM
Great looking work, Sir!
Kurt makes a good point about the bracket attachment, but overall, a very quality build. I especially like the "spider" bit that fits on the nubs at the corners and extends over the top of the frame. Good idea, well executed!
Keep up the good work!
JD Kemp
hughpinder - 1/4/10 at 09:48 AM
Not bad I suppose. What did you do in the aftermoon?
Yours grumpily (after about 3 months getting 1/5 of that done)
Hugh
hicost blade - 1/4/10 at 10:42 AM
What are you doing about an air box??
RK - 1/4/10 at 09:33 PM
Have you seen his airbox description/pics?
