How to attach the sump guard?
speedyxjs - 8/4/10 at 06:24 AM
I have made a nice sump guard for my ultra low sump.
I am unsure though of how best to attach it. I was thinking id weld it but would it ever need to be removed?
mookaloid - 8/4/10 at 07:05 AM
could you ever envisage taking the sump off in situ? or do you need access to anything that it will cover up?
If so it needs to be removable
ReMan - 8/4/10 at 07:25 AM
If youve already made it where did you make it to attach to?
Sump/Chassis/Other?
MakeEverything - 8/4/10 at 07:53 AM
Id make it removeable... Purely in case you did need to take the sump off, seeing as the engine is so heavy. Not an eay one to "Whip out".
MikeRJ - 8/4/10 at 11:43 AM
Weld some heavy duty mounting points to the chassis rails, e.g. a bit of square section cut off the end of a tube at an angle to form a triangle (if that makes sense).
RK - 8/4/10 at 12:17 PM
Check on usa7's or Blat Chat for this. There was an ingenious way of attaching them on there. Basically, cut slots in the guard, and use a hose clamp, wrapped in rubber. Attach to lower chassis. Removable, easy and efficient.
