Inboard suspension locosts?
PSpirine - 1/8/10 at 08:50 PM
What sevens have inboard suspension?
I'm actually asking a bit too late as all the suspension design on mine is now finalised, but thought I'd do a sanity check and see what solutions the others have had!
Pavs
v8kid - 1/8/10 at 09:00 PM
most Silva's
irvined - 1/8/10 at 09:03 PM
I think most MNR's too.
I think my colleagues robin hood has inboard suspension on the front too.
[Edited on 1/8/10 by irvined]
Davegtst - 1/8/10 at 09:06 PM
MK indy R.
scootz - 1/8/10 at 09:10 PM
Quantum Extreme...
FFTS - 1/8/10 at 09:11 PM
Formula 27 (F27)
PSpirine - 1/8/10 at 09:19 PM
Sorry should've clarified...
What cars have FULL inboard suspension (i.e. Front and rear!)
procomp - 1/8/10 at 09:29 PM
Hi
Now ask the question Which manufacturers have developed an inboard setup THAT WORKS. The answer is non. Not even the freestyle Caterham setup worked any better than the traditional outboard setup. And the Westfield FW400 setup was dropped on the final version after the inboard setup was found to be no better just added extra weight.
Cheers Matt
JF - 1/8/10 at 09:38 PM
Matt,
Well when talking front I'd say looks is a factor aswell. And most do get that atleast.
But would you mind reminding me (us?) what the real gain of inboard suspension would be when done right?
And what kind of things do most of them wrong?
Maybe a bit of a hijack, but what about the CCAR system that Dax supply... Any experience with it? Usefull?
[Edited on 1/8/10 by JF]
PSpirine - 1/8/10 at 09:48 PM
My own personal reasons for going to inboard suspension on the haynes roadster:
- The front wishbone shock mount to me looks like it gets loaded somewhat a lot in bending as the shock isn't outboard enough. Now given that there's loads of locosts with the same setup I imagine the severity of the issue is limited, but it just makes me feel uneasy worrying about whether the wishbone will bend over a big bump/pothole. Moving the shock bracket further outboard creates a problem in that a standard length damper can no longer be used, and it increases the shock angle - more regressive spring rate...
- the regressive spring rate. At the angle the front shock is, unless you use some heavily non-linear progressive springs, you'll end up with a softer suspension with increased travel. Undesirable, as far as I'm concerned (and therefore the only reason I went inboard on the rears)
- Finally, adjustment of corner weights/ride height without preloading the springs on the dampers seems like an advantage.
Wasn't for aesthetic reasons, as I actually think that the standard setup looks really good!
Having said all that, we'll see if it works or not once it's built!
dinosaurjuice - 1/8/10 at 09:56 PM
whenever you start introducing more levers and bell cranks into suspension you start multiplying the forces on bits of the chassis. cant really see the point to be honest. Just my opinion.
Liam - 1/8/10 at 10:04 PM
Did it front and rear on mine for various reasons, including getting shocks out of the way of the front driveshafts, playing around with different rocker arm ratios (hence 5 different shock attachment points on my rocker arms), and for fun.
procomp - 1/8/10 at 10:05 PM
Hi
Even if done right there is no gain what so ever to be had that's useful on a seven car or kit car. All it will mean is that the weight has been increased and the cost of dampers needed to do the job correctly has significantly increased. Now look at all the problems that are / have been shown. Chassis need to be increased in strength or you have the extra loads placed on the chassis leading to brackets falling off. Extra loads placed on the wishbones leading to wishbones bending and push/pull rods failing.
The fact that it needs a minimum of double or triple adjustable with remote canisters to be used to gain proper control. And finally it makes the cars much more sensitive to setup thus making every car setting individually for the individual drivers requirements and driving style. This of course not to say it can not be done on an individuals car that is to be used and setup for a particular individual. But if spending that sort of money you are past messing around with a kitcar and into the realms of something similar to a radical where the car is mainly to be used for track only.
Just tacking a chassis and cobbling up an inboard setup like all the kit manufacturers have just leads to many problems. Especially when they can not be bothered to even sort out what spec dampers they need and just supply the same as they run on there out board setups and supply incorrect spring poundage's.
The DAX setup has been proved to be a complete waste of time. Both the works cars that ran it have proved that it is far worse than the original setups. with far quicker lap times on circuit. With much complaining to DAX.
Cheers Matt
JF - 1/8/10 at 10:20 PM
Thanks Matt,
Although you're quite often a bit blunt, it's great that you share your knowledge on here. Well actually you're bluntness is more a blessing then a shortcoming if you ask me. Nicely short and to the point, if only politicians knew how...
The Dax system always seemed way to good to be true to me. If it really was this great then why don't others give it a try aswell. When only 1 company uses something like this that they claim is as good as Dax does... then others would follow shortly... and clearly they don't in this case.
Still like the concept of it though... a shame...
And yeah I can really see the problem with the multiple linkages adding stress and possible play with inboards. Which you really don't want. Personally I'd still want to give it a try really. I really like the clean look of just a pushrod instead of coilovers sticking out. Couldn't be to bothered to do the rear, execpt if space would be an problem.
But then again I've always been to thick headed to go for the logical and sensible option.
PSpirine - 1/8/10 at 10:22 PM
Woah woah woah there Matt, I completely agree you can't just throw it together, but I don't think all your points are valid!
Bending loads on wishbones are all but ELIMINATED with pushrods, as you can put the pushrod right next to your bottom ball joint - wishbone then only sees push/pull, no bending.
Yep, you need to add extra tubes to the chassis, and you add the weight of a pushrod, but it's not a massive increase, especially if it's a locost build which is never going to be an ultralight.
And you do not need different dampers, if the suspension is designed to be used with the standard dampers, it'll work very well, and indeed better as you can build in natural progressive spring rate. As for poundage, yep, mine will need different springs as I'm using a 1:1.2 rocker ratio.
Just because some have cocked it up, doesn't mean it's not worth doing. As for cost, the only increase to me over standard outboard shockers is:
- Four tubes (pushrods)
- Eight rod-ends
- Bush for rocker
- Rocker (made out of 3mm steel)
In the grand scheme of things, not massive, and I'd quite like to have the adjustability, particularly as the roads around here are more rally than race!
scootz - 2/8/10 at 08:55 AM
Hi Matt
Is that just their in-board option or the CC&AR thingy that they offer?
ali f27 - 2/8/10 at 08:56 AM
Mj Hoson bula best set up purdys own works realy well on race car Ali
MikeR - 2/8/10 at 09:07 AM
Went to bed thinking about this and ....
What is to stop you from converting an existing locost (with front suspension mounts under the top chassis rail) to inboard via making a simple rocker arm and shock absorber bracket welded onto some box in the middle of the empty space between the suspension units?
Ok, i appreciate there is some maths to do and this is Matts point that its not just this easy & the shocks are now in warm air flow & the box is now put into bending with no triangulation.
But it just seems without the maths rather 'easy'. In my dreamy state i was even thinking of using a 1/2" rod end for the rocker pivot & perhaps poly bushes for the other pivots (cause thats what is on the shock absorber now). If this makes no sense i'll draw something up, photograph it and post it up.
scootz - 2/8/10 at 09:15 AM
What the feck is an "Mj Hoson Bula"???
Is it like a Flux-Capacitor (only more exotic)?
franky - 2/8/10 at 09:40 AM
Just because one person or company can't make it work or doesn't fully understand it doesn't mean it wont, if every one thought like that we'd never get any development or advancement in technology
Isn't the fisher fury/syliva cars the most sucessful race cars in the class, they use it so it can't be bad.
In fact i'd look for which chassis has won the most races then start from there.
[Edited on 2/8/10 by franky]
procomp - 2/8/10 at 10:43 AM
Hi
No one is saying that it can not be made to work. What i have said is that for the application of a kitcar that will be seeing a bit of track use it is just not worth it. As i said if you wish to pursue it and make it work well you are moving towards the territory of Radical type cars. If you are looking at fitting it to a kit type car that will be seeing mostly road use then you are into a huge development with springs and dampers and the whole front design that will be costing a few £'s. As you'll likely be needing to move towards something like double/ triple adjustable Olin's / penske's Etc Etc. And if you look at what you are likely to gain as a benefit overall when finished you are on a hiding to nothing as it's not like your trying to work with slow speed and high speed with huge down forces.
Sylvas with inboard suspension winning races. Well if you take any of the inboard setup strikers and compare them to a well setup Westfield then you soon learn it a no no. The majority of true successful Inc the works Sylvas where converted back to outboard setup. Even the current RAW setup is flawed and truly requires very expensive dampers and many mods to get it to work as well as a traditional out board setup.
All in all if we are talking 5-15K kitcars do you really need to go adding an additional 5-7 K of dampers to make it handel as good as the traditional outboard setup. However if it's an individual with plenty of time and deep pockets then there's no problem just do it. But i think some are not understanding just how much development it requires and just how sensitive the car / handling can become As i say fine if your developing a Radical type motor for track use but for the average Kit that's being used on the road with some track work then the rules are keep it simple and develop the overall package to be precise well setup with good handling.
Re what was mentioned regarding the Haynes setup. Well your always going to have problems with that type of design because there is no design. Take a basic look at the tracks and wheelbase and ask does it resemble anything that has proved to work. Nope it just way way to big purely so it can use standard production parts with no modification. It's a cheap design for a bit of road cruising rather than a setup that's designed to get round corners quickly.
Cheers Matt
MikeR - 2/8/10 at 10:56 AM
Cheers Matt
This is why i liked my night time thinking - if you take the existing haynes / locost setup as 'good enough'. Then making it inboard means you'll still have a setup thats (hopefully) 'good enough' but ....
a) keeps me from finishing the car so i can be still building in year 11
b) reduces unsprung weight without costing a fortune on new calipers
c) gives me something to think about whilst unemployed
d) is generally accepted to be 'cool' without knowing why
e) has an incredibly marginal improvement in aerodynamics - as incredibly marginal improvements are great achievements in F1 this means my car is now WAAAY superior to everyone else's
f) allows me to move my spring pick up out to the ball joint (which i'd really like to do cause i don't like the current solution - its just wrong to me).
g) did i mention another excuse not to finish the car?
h) hopefully gives me rising rate suspension (or far less falling rate)
Right, i'm off to play with my seating position / steering wheel height again (cause i'm struggling to be able to hit the brake pedal and steer with its current location).
(nb - in case its not obvious, i'm basically agreeing with Matt here, but i've got a 'fun' road car and therefore am happy as long as I don't add any additional compromises or worsen the already made in a shed by me suspension.)
[Edited on 2/8/10 by MikeR]
MikeRJ - 2/8/10 at 11:39 AM
I'm surprised, the Sylva inboard design is very basic with no rising rate linkages or anything fancy - all it really does is allow the shock to sit nearly at right angles to the wishbone which has to be a good thing? A problem with the older ones at least is the bearings in the upper wishbone wearing, but this is really a materials problem.
[Edited on 2/8/10 by MikeRJ]
procomp - 2/8/10 at 12:13 PM
Hi
there's just too much loading placed in to the one area of the chassis. Even the ST setup with bearings was useless. Not to mention the chassis constantly needing to re straightened when the car is subjected to a jarring from road surfaces.
Cheers Matt
MikeR - 2/8/10 at 12:40 PM
Ahh .....
I remember here reading ages ago that the forces can be quite huge. Hadn't thought of that.
(ok, i'm now conceptually picking your brain Matt / others whilst waiting to take the doggy to the vets as it appears he's eaten something he shouldn't and has a blockage - don't ask how i found this out, but cleaning up hasn't been fun).
If i had my lever ratio 1:1 would it still get the huge forces? Say the lever was 20cm long. In the exact middle i had my pivot rose joint. Exactly 8cm from the pivot at either end I had the push rod & damper pivots. If i go over a bump now - would the pivot point and the shock chassis mounting see any greater force than the shock was mounted directly to the chassis?
phelpsa - 2/8/10 at 01:00 PM
You'd have twice as much force at the pivot as at the ball joint as the lever as half as long.
That makes sense to me but i'm not too good at teaching
phelpsa - 2/8/10 at 01:08 PM
Have an FBD:
The force applied down from the chassis must be twice the force applied up from the pushrod (assuming its in equalibrium at the time!)
procomp - 2/8/10 at 02:32 PM
Hi
In basic terms. Yep it will place more load on the chassis how much more will be down to angles of pushrods and dampers. As well as the spring poundage differences required for the different setup. The Sylvas are not far off a 1-1 ratio but haven't got specific details to hand at the mo.
You will also suffer pivot problems such as those on the sylva setup.
Cheers Matt
MikeR - 2/8/10 at 02:43 PM
What pivot problems?
My cunning dream plan was to use a 1/2 inch rose joint as the pivot, this would be mounted in the box that formed the pivot. As rose joints are used to taking suspension loads, they are great at having things turn around them and can take up a slight amount of missalignment they seemed ideal.
Later this morning it also occurred to me they have no ability to stop my pivot twisting, so now its two rose joints, one either side of my existing suspension pick up point and a crush tube where the shock would normally go.
As the weight on the chassis doubles on the existing shock pick up, we've got three choices,
1) replace that section with thicker steel.
2) limit the engines to bec's (if the existing mounts can take P&O anchors and V8's then a bec will give things an easier time
3) drive it till it starts to fatigue and add extra steel at the weak points.
p.s. stupid thoughts stop in 1 hour
bi22le - 2/8/10 at 02:55 PM
when i went searching for a kit car to buy i looked at the kit car race series. With raw and sylva chassiss seeming very competitive i considered that the only way to go. The coil overs on my raw are nothing special at all. Shorter throw with different springs and thats it. This is a tried and tested chassiss that has had years of development and setting up. Buying a a raw buys you that tried and tested setup.
Refering back to op and changing or building an inboard thats where all of the above comments are very relative and i agree to a certain extent. I think that if you want to build your own inboard setup then give it a go. It sounds like you would enjoy the work and testing. Something else to be proud of when its finally going around the track.
ali f27 - 2/8/10 at 03:36 PM
Hi scootz will get photo up of mj hoson bula cheers Ali
procomp - 2/8/10 at 03:50 PM
Hi
Don't underestimate the loads present. there where a few sylvas modded to use rose balls either side of the pivot. Lasted less than 1000 miles.
bi22le. Now having done a fair bit of work on the RAW strikers with in board suspension with dampers and anti roll bars Etc. Can you tell me which of them is running a chassis that is as it was when it left Raw unmodified. And running less than 2k worth of dampers upfront.Cause that rules out all of the cars that have competed in the 750. championships. ?
Cheers Matt
bi22le - 2/8/10 at 09:50 PM
Er nope. . . .
Sam_68 - 14/8/10 at 11:35 PM
Originally posted by procomp ...the Westfield FW400 setup was dropped on the final version after the inboard setup was found to be no better just added extra weight.
Incorrect. The FW400 was not designed with inboard suspension and the set up was not 'dropped on the final version'. The car as designed by Martin Ogilvie was always outboard. There was a later conversion of a couple of cars by Pilbeam, which Martin never approved of; to the best of my knowledge, though, the cars converted (which now live in Japan) are still running the inboard set-up.
A fair proportion of what you've said about Sylvas is pretty much cobblers, too, but I know the size of the axe you've got to grind on that subject, so I really can't be arsed arguing it all over again with you.
[Edited on 14/8/10 by Sam_68]
andyps - 5/9/10 at 09:01 PM
Well, my first post for many months, if not even years on here so if I am out of touch and wrong, apologies in advance!
The obvious answer to the question about a seven with full inboard suspension is the Caterham CSR - at £42900 fully built it is not exactly locost however, but does show that it can be done, at a price! All reports suggest that it drives very well.
When I get round to working on mine again I will be doing inboard rocker arm suspension, I have made the appropriate parts on the chassis for it, and will eventually make the wishbones. One thing I haven't decided is the ratio to use on the rockers, but have figured (I think) the mountings and everything else. I can't remember but am pretty sure I posted some pictures on here when I originally made that part.
Volvorsport - 5/9/10 at 11:02 PM
inboard
RK - 6/9/10 at 12:16 AM
People love reinventing the wheel, don't they? If it makes people happy, why not? However, I don't see the point in trying to turn a 50's era fun car into a modern single seater, which it isn't and never will be. Creativity doesn't have to have a point though.
scootz - 6/9/10 at 11:11 AM
I thought it had a fair number of critics who thought the 'old' set-up was better!?
Neville Jones - 6/9/10 at 07:00 PM
Most of what Matt says is very correct.
But, the biggest mistakes I see are in the design of the rockers themselves. Inboard with rockers was developed in the open wheelers to cut down drag, improve polar moments, and packaging.
In racecars the inboard setup works well, because the amount of wheel movement is usually kept to near zero in droop, and no more than 40mm or so in bump. When you get to the movements needed for a road car, the size of the rockers needed is astronomical compared to a racecar. The small rockers udsed by most amateur builders end up producing all sorts of undesirable effects at their limits and beyond.
As a final note, what's wrong with a properly designed outboard setup, with properly designed wishbones and coilover pickup geometry? Caterham have been doing it for years.
Nev.
JF - 6/9/10 at 08:16 PM
Whats wrong with trying something for yourself instead of simply doing the very same thing over and over again.
If everyone had always done that, we probably wouldn't even exist...
Sure could be that most 'amateur' inboard setups are inferior to 'pro' outboard setups. But most of those 'amateurs' might never even notice the difference... As they're not pro racing drivers. They might never even drive a single mile on a circuit.
So who gives a f*ck if it's not as good as X. As long as that 'amateur' is happy with the result....
scootz - 6/9/10 at 08:29 PM
I suspect they would! Screw up an outboard set-up and it's nasty... screw up an inboard set-up (very likely if you don't have specialist assistance) and it will be absolutely rank rotten!
JF - 6/9/10 at 09:07 PM
Well might have come accross a bit grumpy, but my point is... Live al little and try something. Experiment. Because really... why else would you want to build your own car when you can just buy a standard tintop...
ceebmoj - 5/4/12 at 10:07 PM
Originally posted by Volvorsport
inboard
Why would an inboard set up be mutch worse than an out board set up? Also can you point out the problems in the above set up? found the thread through a serch so was suprised my the resurrection.
[Edited on 5/4/12 by ceebmoj]
phelpsa - 6/4/12 at 08:07 AM
inboard
It isn't much worse. It can be better in certain circumstances, but in the kit world those circumstances are quite rare.
The problem in that setup is that you have more than twice the corner weight of the car trying to rip the rocker bracket off the car. Its not what you would call a 'material efficient' design.
ceebmoj - 6/4/12 at 10:18 AM
Given that it might not be material effishent, can a rocker set up ever be efisent in that way ? Do the benafirs of
1. Rising rate suspention with the corect
Rocker.
2. Using a lager % of the shock travel
3. Moving the actuater point on the bottom wishbon closer to the balljoint and Moving another thing out of the air stream
and any othere things i dont know about make it worth wile
phelpsa - 6/4/12 at 10:34 AM
Rocker.
You're basically trading off different inefficiencies of the two designs.
The problem with most of the inboard setups on spaceframe 7s is that they aren't there for any reason other than to have inboard suspension, and they have ended up with the inadequacies and inefficiencies of both designs (large bending moments in wishbones, high wheel:damper ratios and reduced system stiffness).
An outboard system is much much easier to get right, and with some reasonably simple design can be 90% as competent and 50% of the weight of a properly engineered inboard system on a spaceframe 7.
If you're chasing small drag reductions on a 7 then you're in the wrong business
rdodger - 6/4/12 at 03:25 PM
I have always wondered why kit manufacturers use inboard for a much more simple reason.
They all appear to place the shock directly behind the radiator. So what happens as the hot air flowing out of the radiator heats up the oil in the shocks? Surely the viscosity changes and the damping alters?
I know shock oil is meant to be quite stable but since expensive shocks and small bike shocks have remote reservoirs to prevent this. What happens to our cheapo Protec or Gaz shocks?
I asked a couple of manufacturers this question at a show last year. I was basically told to bugger off.
Twin40 - 10/4/12 at 12:29 PM
thought i'd do a little 'internet research' and managed to stumble across this....amazing work
http://www.kirkhammotorsports.com/book_aoe/aoe_12.pdf
certainly not locost!
mcerd1 - 10/4/12 at 02:39 PM
Hi Matt
^^ I assume he's talking about the inboard ones, dax did make a few cars with inboard shocks, but never really put them into production.
the CC&AR has always caused a bit of debate, its patened though so othe manufacturers can't use it even if they wanted to...
this is the new rush chassis they were showing off at last years open days (BMW E36 / E46 donor)
dream - 10/4/12 at 03:54 PM
dream - 10/4/12 at 03:55 PM
does someone have pictures of the front suspension of the mirach ?thanks
MikeCapon - 10/4/12 at 04:23 PM
A bit off the topic of the thread but the remote reservoirs on a lot of bike shocks and high end car shocks are not there to provide cooling. They are primarily a gas chamber although some of the heat generated (not a lot as it's only the lower compression forces) is generated in the reservoir and hence there will be a slight improvement in dissipating heat but only really due to the increased surface area.
The real answer to limiting fade through heat is the use of lighter oils with higher viscosity indices together with well engineered components.
hughpinder - 11/4/12 at 11:58 AM
I thought about going inboard with my front suspension, but didn't in the end. Here was my reasoning:
The pros were:
a) Looks nicer.
b) Allows creation of really neat/small and light anti roll bar
c) Easy to set up for rising rate, but you can also do this if the suspension is outboard (not to the same degree though) - just put the upper spring mount point so it is outboard somewhere between:
1. the arc drawn with its centre on the lower arm chassis mount and the 'drawing' end on the lower arms lower shock absorber mount, and
2: the point where a tangent to the shock absorbers lower mount does not pass through the upper mount point at maximum bump (otherwise the rate will start to drop)
The cons were:
a) Gain in aerodynamics from putting the shocker/spring inboard offset by the fact they are still in the airflow behind the radiator(less because the air is slowed by the rad though), and extra introduced by the push rod and lever.
b) Extra cost for bearings and rod ends
c) More parts to fail/maintain
d) Extra metal for shocker mounts inboard
e) Extra strengthening of upper chassis bracket/rocker mount required.
f) Exponential increase of 'wheel rate'and spring poundage if inner arm is shorter than outer
g) You will need double adjustable shocks at least so more £££
h) Shockers are in the hot air flow from the rad, which isn't especially good.
i) little experience in setting them up properly to draw on, seemed like even the 'proper' companies had design problems like rapidly wearing pivot bearings/problems getting a good ride, chassis rails bending......
Just my thoughts when I did my early design decisions.
I'd still like to do it though, and may do if I build a second car!
Regards
Hugh
loggyboy - 11/4/12 at 12:09 PM
You missed the pro of less unsprung weight
Also some of the cons can be easily negated by good design:
I think the engine thats sat right behind the shocks would be alot worse!
Extra cost for bearings and rod ends can be designed out
not with good design
why?
[Edited on 11/4/12 by loggyboy]
hughpinder - 11/4/12 at 12:28 PM
Ah yes, I did consider the unsprung weight at the time, but I forgot to mention it. I believe its traditional to consider half the weight of the shocker/spring as unsprung - I couldn't decide if the unsprung weight actually goes up since the pushrod/rocker and half the shocker/spring weight are on the 'wrong' side of the spring and still need to be moved by the spring and damper relative to the chassis, to keep the wheel in contact with the ground.
Mines a midi/rear engine which I forgot to mention, so the engine thing didn't figure in my design I suppose!
I don't see how the extra cost of rod ends and bearing can be designed out, as in one case you need them, and in the other you don't!
The exponential increase in wheel rate etc can only be designed out by having a 1:1 arm ratio, hence my caveat "if inner arm is shorter than outer ". I couldn't get a packaging setup that allowed better than (inneruter) 1:1.2 in my design, but I could have gone for a setup with the shockers offset front/back to avoid overlap I suppose.
The double adjustables I suppose is hearsay as I have no sound design reason for saying it - I just spoke to almost anyone I could running inboard setups at trackdays/hillclimbs/races and it seemed everyone had already changed to them or thought that they needed to!
Regards
Hugh
Twin40 - 11/4/12 at 12:51 PM
Regards
Hugh
This intrigues me as i understand the principle behind single bump/rebound adjustable shocks, and the benefit of "2-way" shocks ( i ran them on my tintop) - but i can't understand how running inboard suspension effects the performance of the single bump/rebound adjustment shock? and require a double adjustable to provide a better set-up?
Does the rocker ratio have a significant effect? Do you need to compensate for a difference in compression? (i'm building an Indy R for racing so this is a particular concern!)
[Edited on 11/4/12 by Twin40]
hughpinder - 11/4/12 at 01:20 PM
twin40, As I said, I didn't have a sound logical reason to see a requirement for the 2 way adjustables - it may just be a symptom of things not really working and people thinking more adjustment=better! It was about 4 - 5 years ago too, so not as many inboard set ups were around in actual use. I believe its very difficult to set up 2 way adjustables optimally.
The effect of the lever ratio is quite significant. If you have a certain weight on the front wheel, you need a certain spring poundage to resist that weight. The shorter the inner arm is relative to the outer, the higher the spring rating will be to resist that weight (think of it as equivalent to moving the shocker mounting point on the lower wishbone closer to the chassis by that ratio o an outboard setup). The 'wheel frequency' goes up in inverse proportion to the square root (e.g shorter = higher frequency) of the lever length and the spring rating, so if you have a lever ratio of 2:1 your spring will have to be twice the pounds rating and the wheel frequency will go up by a factor of 8! (this is all from memory so it may be worth checking in a suspension book like staniforth or similar). I'm not an expert - these are just my conclusions from my own design. From memory a wheel frequency of 60-80 was normal road car, 120 about the comfort limit , with full on race cars 200 up to about 400. I'm sure someone with more practical design experience will correct me soon enough!
Regards
Hugh
phelpsa - 11/4/12 at 06:39 PM
Regards
Hugh
You're making that sound a lot more complicated than it need be Everything you have mentioned is as valid for outboard as it is for inboard.
What units are those wheel frequencies in? Certainly not Hz!
hughpinder - 12/4/12 at 08:16 AM
phelpsa
Sorry if I've made it sound more complex - I was hoping for the opposite.
It's true that the rising spring rate and higher wheel frequency also occur on an outboard set up - but only if you move the shock absorber mounting point closer to the chassis pivot point, and this is unlikley to be chosen, as almost all designs anyone is likely to copy have the mounting points as far outboard as possible, and also this is where the tubes join and it makes the easiest to fabricate arm design - I dont think Ive ever seen one with the mount half way along the arm, but I'm sure people will immediately provide plenty of pictures! On the other hand, a lot of people don't think about a 20% difference in pivot lengths as particulaly significant, but it needs at 20% stronger spring and a 70% higher wheel frequency! (This is not quite accurate - as you move the pivot point inboard the spring becomes less inclined to the vertical, and this reduces the spring strength a bit).
Sorry - I've had to look up my original notes/calculation to find the frequency units - it was cycles per minute! I'm not sure why - Hz seems a much more natural frequency to use for me (I think the calculations came originally from the Staniforth book).
Regards
Hugh
