Hi all,
I am building my own custom design chassis, and I can't make my mind up as to what engine and where.
I am thinking of mounting a bike engine in the rear, providing the power direct to the wheels. But so far I have built the chassis to take the engine
in the front.
Swings and roundabouts, bike engines are built for bikes, and if its in the rear it will probably make the car wheely.
What's your thoughts.
I think you need to go to Newark in a couple of weeks and have a look at those already around. Just because they are bike engines, doesnt mean it will make a car wheelie.
Not to mention the ASBO http://www.locostbuilders.co.uk/forum/52/viewthread.php?tid=170854
I never said that it wouldn't wheely with a car engine in the rear.
I am going to Newark in a few weeks, hopefully with my trade stand.
I have been looking around again thismorning and I think I am going to put the bike engine in the rear. I will try and post some pics later.
Surely it wont be rear engined? It'll handle like poo.
No offence, but if you need to come on here, to ask whether you should put your engine in the front, or the back, then I would think you need to do
some more reading! By rear engine, I assume you actually mean mid-engined? Ie just behind the seats, but well ahead of the rear axle....?
If your chassis is built for front engined, I think you would be foolish to try and re-engineer it to mid-engine - I would start with a middy instead!
Just my 2p worth!
Good luck with your build.
either front or midengined. Unless you got millions and porsche contacts I wouldnt do that. You want the weight inbetween the axles. Let us know what you decide
Hi there sa-fabrication,
Where are you based? Welcome to come and have a look at mine sometime if your near cumbria??
I had similar ideas to you and built my own chassis design around the standard locost putting my transverse drive train in the back. The 20v turbo is
canted farward and means its COG is going to be about 500 - 600mm in front of the axle, meaning mid engined.
Have a look at the work i have done, you might get some ideas.
quote "But so far I have built the chassis to take the engine in the front."
I have to agree with some of the other comments though, if you have already built your chassis to take an engine in the front, you might as well carry
on as intended..... Its going to look a bit funny being as long as a standard locost and then a big section at the back also....just my opinion. My
car retains almost the same wheel base as the standard locost but the front is a lot shorter.
A lot of work went into redesigning and developing to put the engine in the back. 2 years on and still not started it in steel yet! LOL.
Rob
