what is the best chassis for a bike engine
rick1962uk - 18/9/12 at 07:04 AM
hi at last im going to start building a bike engine 7 just in the planning stage so a few thought to help out will be great
what chassis is the best to go with rons or haynes or are there any good premade ones out there for decent money i was going for a taylor racing one but there site looks like they dont make them any mooe but dont mind making one
this will be for track days only
many thanks rick
adithorp - 18/9/12 at 07:40 AM
You'll probably get as many opinions as there are chassis.
Do a search on...
Raw Striker
RoadRunnerRacing SR2
MK Indy
MNR Vortex
Mac #1
Westfield
Sylva Riot
...and thats just for a start.
mark chandler - 18/9/12 at 07:58 AM
I suggest you look for the lightest chassis when all built up, put a passenger into a BEC and it will slow down, do not start off heavy.
So if going for a home brew then Ron's over Haynes, its's smaller and lighter.
As it's for track look to land a full cage where tubes align so build the cage into the structure rather than place on top and use the correct tube as specified in the MSA blue book.
Regards Mark
jossey - 18/9/12 at 08:28 AM
Not the tiger unless your off for a small engine.
My zzr1100 won't fit without 50mm out of top and 40mm under chassis.
Zx9r wouldn't fit without cut out either.
My old locost chassis worked well with zx9r and zzr1100
PAUL FISHER - 18/9/12 at 08:47 AM
many thanks rick
Stuart Taylor racing, are now called Aries Motorsport, link to there webb site below, great chassis and good value for money, nice and light weight
http://www.ariesmotorsport.co.uk/
JimSpencer - 18/9/12 at 08:48 AM
Hi
Track use only moves the goalposts somewhat, so here's my 2p:-
Sylva Riot or something similar - i.e. rear mid engined..
Engines in the right orientation, simple install, no prop etc and hence it'll be very light..
MikeRJ - 18/9/12 at 09:10 AM
A bike chassis would be ideal
nick205 - 18/9/12 at 09:56 AM
hehehe, that made me chuckle
twybrow - 18/9/12 at 11:14 AM
many thanks rick
+1 vote here too. Great chassis and fits a bike engine well. The only issue you may have is the height of your chosen engine as the Aries/ST is quite low compared to others.
TimC - 18/9/12 at 11:49 AM
For track days only I'd go for a Procomp chassis. See www.procomp.co.uk
To be honest, you'll have to ask them nicely to do the bike mounts for you but they are good guys! Being Live axle the only engine that you can really use will be an R1 1998-to-2008. Plenty of choice.
bi22le - 18/9/12 at 05:02 PM
+1 for the lightest you can find and build.
If your out and out track then it needs to be small and light. The smallest cars I know of are
RTR (road track race) Atomic
Sylva R10T
RAW Striker.
RTR Atomic is single seater but with the engine next to the driver for optimum COG. These cars are tiny!
rick1962uk - 18/9/12 at 05:58 PM
MANY THANKS SOME GREAT CHOICES ENGINES NO PROBLEMS AS IM A MOTORCYCLE ENGINEER FULL TIME TUNER / RESTORE SO LOADS OF ENGINE CHOICES BUT SEE WHAT I GET GIVEN
snapper - 19/9/12 at 05:50 AM
Incurious Why only the R1 with a live axle????
adithorp - 19/9/12 at 07:24 AM
I suspect he means because the inj' R1's have a higher final drive ratio than other bike engines, so work better with the available live axle diff ratios ???
TimC - 22/9/12 at 08:28 PM
Exactamundo Adi. Carb'd 'Blade is the other option but why would you these days?
mark chandler - 22/9/12 at 08:59 PM
Easy emmisions, good power to weight and stick in a baffle plate and you are on the track so very cheap with a plentiful supply of replacements at under £400.
A good 893-919 blade car well driven will beat others and gears are perfect for fixed axle/cheap sierra ratio's, so cheap to start off with and cheap to keep going.
