Hey
has anyone built a locost with trailer coupling?
is it possible?
rudi
Do you mean to tow a trailer..
Or do you mean to latch teh locost onto the back of your Family estate when going on holls...
Either is possible..
I am planning on doing the latter.. And I guess that it could easily be made to act either way..
TT
I saw a massive mobile home towing a fiat cinqueceno tender-boat style the other day, first time I'd seen anything like it.
To do it on a locost i guess you'd just need a strong a-frame that you can pin or bolt to the front of the chassis (with some rodends maybe) and
a bit suitable for a tow hitch. I'm guessing you'd probably want to hook into the locost's loom for rear lights too, that could be
interesting.
As for a trailer for a locost, that could be fun too but then you much stuff do you really need to take to lemans with you
I've seen two Locosts and three Robin Hoods fitted with towbars.
However your towing capacity is limited by the weight of the Locost and by law, although not sure what it is.
A small 5x4 trailer is probably it's limit.
That would be big on a locost. I have one that size which regularly carries 1/2 ton of stuff which is approximately the weight of my car. It would have to be braked to use it on the locost.
I was thinking of something more like this:
You could make it a bit wider, about as high as the top of the rear panel and give it looks that fit in with the rest of the car. It would be a cool
project if you intend to do a lot of touring in your locost.
Yes, itīs great.
but the towing car must be a seven, and the trailer is the rear of seven.
"mother-in-law-seat"
has anyone pics?
rudi
Pete it was a guess at the size. Probably 3x3 then eh?
I think you are allowed to tow 1/2 of the cars weight with an unbraked trailer. This includes the trailer.
I was wondering about at least including some metalwork on which a towing bracket could be mounted at a later stage if I wanted. The only thing that had occured to me is that every tow bar i have fitted to a car has been made out of much heavier tubing than the locost chassis which makes me wonder whether this would be really necessary!
many of my biker friends tour with a trailer and they have no issues with it at all, one of them even tows a small trailer tent behind his yammy
XJR1200 - looks most bizzare!
I would like to have the provision to attach a small trailer to my car in the furure because i plan on doing plenty of camping etc.
I drew up some plans some time ago to retro fit a tow bar to my F27 which wuld be covered by the spare wheel on the back when not in use - cant find
them though
[Edited on 15/9/04 by colmaccoll]
cheers
I have asked Luego to fit up a bracket for a towball on the Viento I have on order. I too only want a small trailer. I would suspect that the
strengthening needs to go through the boot area to the Main chassis area. This is probably fairly easy on a IRS back end, but maybe not so easy on a
live axle back end.
I want a small camping trailer for weekends away with the Wife.
A small trailer will not need brakes if its max weight is under 750Kgs. Which it will be. I would also not want it to exceed the car weight. I have
not spoken with Luego about the spec of "Max Braked Trailer towing limit" which is in most cars handbooks.
However as you are the manufacturer of your Locosts, you may be able to do your own thing.
Personally I would not want a (loaded) trailer to weigh more than 85% of the car, as this is the AA, RAC, Caravan Clubs reccomended Max. The max
weight is down to the design of the vehicle and stipulated by the manufacturer. I dont know how this stands with a Locost.
What ever you do, make it strong and SAFE. Launching a 500Kg trailer down the fast Lane of a motorway, is bound to cause an accident. Also with a
light car, you dont want to jack-knife or roll your pride an joy due to having too much weight behind you, or due to the towing point tearing out as
its not strong enough or poorly designed.
What I am trying to say is take great care, as you could be fabricating a major problem if you get it wrong.
I am sure you all realise this, but I feel it has to be brought to the surface. I am not a trained engineer either, but think 10 times - build once
(and correctly!). Take professional advice if need be. Its cheaper than your life! (or someone elses)
Safe towing to you all!.
GeoffW
Originally posted by Pistensau
....the trailer is the rear of seven.
"mother-in-law-seat"![]()
If it's just for the mother-in-law, surely a couple of bungee cords would hold her onto the back of the Locost.
I know her head and feet wouldn't aid the aerodynamics (but yours may be one of the really short wizzened old grannies).![]()
I live close to Witton Castle near Bishop Auckland (Co. Durham). Last week saw the annual meet of the MAG (Motorcycle action group) for the 2004
Stormin the Castle. I observed several Goldwings and custom trikes that were towing trailers. One of which was a trike that was towing a trailer tent
(posh camping). I guess that would give some idea of average towing weights that could be applied to a locost. I saw a few of these travelling on the
A1 where there was a heavy police presence.
It makes a lot of sense to be able to tow a small trailer that could give boot capacity for camping holidays or ability to take some luggage. The
trailer would not therefore need to be too large - something like the small ones sold by Halfords that appear to be fairly lightweight with aluminium
bodies - altough a locost rear body on a lightweight frame would look so much more fitting. Im no towing expert but would suggest less than 85% would
be sensible as there is no weight in the back of a locost. Even 60 - 70% would allow a lot of scope for luggage etc.
If anyone comes up with an idea for attaching the tow bar i'd be interested to see it.
Darren.
Shuv ya mother in law on a skate board holding a bit of rope. She'l soon let go..
Ive thought of adding a trailer too. Only a small one probably the back end replica jobbie.
Ive seen loads of minis like it and even an old meastro van!!
Originally posted by DarrenW
I live close to Witton Castle near Bishop Auckland (Co. Durham). Last week saw the annual meet of the MAG (Motorcycle action group) for the 2004 Stormin the Castle. I observed several Goldwings and custom trikes that were towing trailers. One of which was a trike that was towing a trailer tent (posh camping). I guess that would give some idea of average towing weights that could be applied to a locost. I saw a few of these travelling on the A1 where there was a heavy police presence.
It makes a lot of sense to be able to tow a small trailer that could give boot capacity for camping holidays or ability to take some luggage. The trailer would not therefore need to be too large - something like the small ones sold by Halfords that appear to be fairly lightweight with aluminium bodies - altough a locost rear body on a lightweight frame would look so much more fitting. Im no towing expert but would suggest less than 85% would be sensible as there is no weight in the back of a locost. Even 60 - 70% would allow a lot of scope for luggage etc.
Darren.
Thought that this from Les Newells site might be useful http://www.lnewell.free-online.co.uk/Chassis.html
