Hi, I am new to this forum and looking for help.
Story so far bought a Tiger Avon Chassis from ebay two nights ago.
Before I waste a lot of time was wondering what the experience guru's on this forum advise me to do for sourcing front and rear wishbones ready
for fitting the suspension. Cheers Ste.
Where are you in the world?
In the Uk, Located in between Manchester and Liverpool
You have U2U
I just fitted snake Bellys wishbones last night.
If your wanting to do track days get them :-)
Ohhh n the wishbone ball joints are top one are the transit drop link, they do 2 one about m18 and one about 1" it's the thinner one.
Second is bottom one which has caused me he'll. they are fiat 124 qsj765 about £9.50 each. They are not 3 bolt maxi.....
Other than that good luck.
I had my wishbones fitted last night which are great. They are 30mm wider to remove under steer or reduce it.
http://www.locostbuilders.co.uk/forum/22/viewthread.php?tid=177544
Getting new ones from tiger are £220 plus postage.
I hope this helps
[Edited on 5/1/13 by jossey]
Hi David, thanks for the advice
I think my plan will be to keep the set up standard until I get it IVA for the road.
Snakebite modifications look very good and i will consider them in future
You dont want to sell your standard ones by any chance?
oops i quoted Snake Bite - appoligies its Snake Belly
Just clarify the new bones will have no bearing on iva, they also come with a sleeve nut camber adjuster built in. Not trying to dissuade you I don't do these as a commercial proposition just as a service to the Avon crowd after spending a couple of years developing them on our race Avon. All I would say is that quality is not compatible to the factory items, the polybush tubes actually line up for a start :-) although they work out about the same cost I woul be remiss not to point out that tigers are powder coated and mine come in bare steel. Hth and good luck with the build.
Oi.... Will you enjoy your holiday n bugger off.....
Fitted bones last night. Thanks.
Hi, firstly a big thank you to everyone for all your feedback and advice...
Snakebelly, only just noticed the U2U option on this forum and read your link..
I agree your wishbones look a far superior product and if I have to buy a set of new ones I will be giving you a shout. However as I need a full set
for both front and rear of the chassis and I am not in any rush I am going to see if I can pick cheap set of second hand ones up whilst I start to
identify/collect other items for my build to store in my garage ready for assembling my project at a future date... At this moment I have only just
started reading up on the Tiger Avon and have not made any decision on what route my build with take,,
Thanks Again and hope you enjoy the rest of your Holiday
Steven,
One thing I have earned from having a tiger after getting rid of my locost is nothing fits from the locost with a mod or not at all.
Front are rear wishbones are different from everything else.
Body panels are tiger only
Rear prop is standard
Steering Column is heavy modded
Rack needs modding
The body is narrow so seats don't normally fit with extra thin ones
Chassis is low in height so fitting an engine is harder
Fuel tank is a struggle to get a generic one to fit
Pedal box has to be floor mounted if your tall
That said I love my car and it will be much better on the track and daily road use than all the other options I looked at.
Don't make the mistakes I made.
Buy the tiger avon book from Laura at tiger first and get the bits from someone who knows tigers.
Good luck.
Ps give neilp a call he is stripping an avon and has a lot of parts.
Thanks for the Advice David
Got a feeling it's going to be a long slow build!!! Ha. Will try Neilp
Hi David - do you have contact details for Neilp. Looked on members list but it is not showing any email address? Cheers
If your looking for used parts we have a type 9 to sierra props haft and also a spare ford viscous LSD not used since it was rebuilt by road and race
transmissions its a 3.62,
Any off to swim with elephants :-)
