Are there any MSA scrutineers out there?
I need to define the roll hoop on an open top LMP style car, I'm working on, but not sure how much flexibility there is from the diagrams in the
blue book. Basically, according to the diagram, it should be a single hoop, with at least one diagonal cross brace and two forward running braces. The
diagram shows the verticals as...vertical. Like this picture of the AB Sabre (pic below)
Whilst, I actually prefer the style of those cars, where the verticals actually angle in. Like the Spire (pic below)
The long and short question is, if I do the cage, as per the Spire, is it MSA compliant or is it only possible to deviate from the diagrams, if
you're an approved roll cage manufacturer or the design has been in some way tested and certified.
Thanks in advance, for any help!
Build it like the diagram or you have to have it approved by the MSA. I'm sure Andy or the Procomp guys will be along to add detail to that.
Just spotted you post - basically it is fairly straight forward despite being laid out a little poorly in the book - build to the exact spec using the
approved configurations, mandatory elements and material spec as laid down in the blue book and you have a protection system compliant for events run
under MSA regulation. Change the design, material spec or need FIA approval and you are going down the certification route or purchasing a compliant
system from a supplier.
Hope that helps
I need to define the roll hoop on an open top LMP style car, I'm working on, but not sure how much flexibility there is from the diagrams in the blue book. Basically, according to the diagram, it should be a single hoop, with at least one diagonal cross brace and two forward running braces. The diagram shows the verticals as...vertical. Like this picture of the AB Sabre (pic below)
The long and short question is, if I do the cage, as per the Spire, is it MSA compliant or is it only possible to deviate from the diagrams, if you're an approved roll cage manufacturer or the design has been in some way tested and certified.
