I have my gearbox out at the moment, as I'm going for a rebuild and higher 1st gear. Anyway, it made me think about the rear mounting point,
which I know is the lowest point on the car after going over speed bumps!
I kept it as on the Sierra, where a bolt with a long hexagonal end goes through a bell-shaped "washer", then the earth strap is screwed to
the end of this hexagon. My question is why the need for this bell-shaped washer? Can't you just leave that off and put an ordinary set screw
through the earth strap ring terminal and on into the gearbox? This would significantly raise the lowest point on the car, while still mounting the
gearbox and creating an earth...
Pete
The big dished washer was installed to a , spread the load on the mounting , b, to stop the bolt pulling through the mount. Fitted a heavy duty mount without the washer on my car
Hi Rusty. So you're saying the box can bounce up so hard that the edges of the "bell" actually contact the mount?! That's a fair bit of flexing of the rubber. At least the design makes a bit more sense in that case. Where did you get your heavy duty mount?? Might have to consider one.
Cheerz
I never put that washer on mine!
14 years it's been on the road now, never had a problem.
I replaced mine with a home made copy of a vibra technics type 9 uprated mount (i looked at the price and thought i can make one of those in an hour).
It stopped an annoying judder that occured at certain rpm/loads and is far more effective than the mushy sierra one.
Pics:
https://www.dropbox.com/sh/m9eo8if8hlh1es6/AAAiSemOe5OiMFzkO1VuO_Oya?dl=0
The bell washer is to tether the gearbox if the mount fails (used to happen often with old sierras) or if the vehicle grounds out on the gearbox,
before i changed the mount i placed a thick exhaust mounting rubber over the washer before fitting to take up some of the movement, without it the
gearbox would knock on the chassis when accelerating and on overrun.
Dave
Originally posted by obfripper
I replaced mine with a home made copy of a vibra technics type 9 uprated mount (i looked at the price and thought i can make one of those in an hour). It stopped an annoying judder that occured at certain rpm/loads and is far more effective than the mushy sierra one.
Pics:
The bell washer is to tether the gearbox if the mount fails (used to happen often with old sierras) or if the vehicle grounds out on the gearbox, before i changed the mount i placed a thick exhaust mounting rubber over the washer before fitting to take up some of the movement, without it the gearbox would knock on the chassis when accelerating and on overrun.
Dave
They were some drop links bushes from a mk2 astra drop link, but anything of that type should be suitable for the load. IIRC they're 20mm thick,
25mm diameter and a 8mm bore, and the plate is 6 mm thick, folded in the press and welded together.
Dave
