Calipers - leading, trailing - front, rear
JAD - 11/5/05 at 05:09 PM
Anywhere that I can check-out the merits for location of calipers?
John
kb58 - 11/5/05 at 05:45 PM
Not that I know of. The only rule is to have the bleed-screw at the top of the assembly. After that it's whatever you want. At the back I'd put them on the foward side of the upright, and at the front put them at the backside. It'll very slightly improve rotation inertia of the car as a whole (not related to rotating tires or wheels...)
britishtrident - 11/5/05 at 06:28 PM
Dosen't make any difference unless the wheel bearings are grossly over loaded - in which event rear mounted calipers put less loads on the bearings under braking.
