i want to coat the ali panels to keep them from looking tatty (they are already looking a bit scratched from clamping whilst triming them) before i rivet them on. any ideas on whats best? (powdercoat/paint?)
Hi mate - you need to do the following:
a) clean down with gunwash
b) ETCH primer
c) 2 pack paint
I've done it to my alloy side panels - look ace IMHO and much more resilient than bare alloy.
The ETCH primer is the important bit - as you need to 'key' into the alloy.
My experience with powder coating is limited, but I always see poor results - once it starts lifting = game over.
At least with paint, you can touch up ;-)
HTH
Murray
[Edited on 7/8/06 by muzchap]
Ive used this to cover the ali sides on my loco.
clicky
Was going to get them painted but got a roll of this for £25 so decided to give it a go. Its holding up very well.
I used powder coat because it was cheaper than buying all the painting materials and much quicker too.
--Chris
I second the powdercoat; it has worked well for me. I don't regret it.
clicky
clicky
How easy is that to apply without wrinkles? Does it cover up minor scratches or do you still need to sand/fill etc?
That is very tempting. Side panels on the Striker are in a bit of a state, especialy where someone has trimmed some race numbers straight onto the
alloy with a stanely knife.
Was going to flat them back with wet and dry and spray them, but this seems like a interesting option.
I don't know what this would be called in the UK or whether it is available there but I am going to use Linex truck bedliner sprayed lightly
inside and outside the tub area. The advantage is, at least here, it has a lifetime guarantee that it won't come off. I know a circle track guy
who had this done and he said the total weight was 20 lb less than a paint job. This will totally seal the frame to the panels and eliminate
corrosion and should actually strengthen the chassis.
[Edited on 9/8/06 by locostv8]
Line-X truck bed liner is available in the UK: http://line-x.co.uk/page.asp?name=locate_a_dealer&now=9304
Yes that'll work well, but so would brushing on tar.
Does it matter what it looks like? Before signing up for the stuff, find out how much weight it'll add to your car. It may be fairly shocking.
The Line-X stuff goes on really lumpy and it's Heavy.
Actualy it is fairly shocking what a paint job weighs. As I said a Circle track guy did his car because he was tired of stone chips and was surprised that it was lighter than paint. The coating is a two part polly process and is sprayed in multiple coats to get thickness. The bumpyness is the last coat and is done for cosmetics. The finish can be done to look much like stone guard and does a prety good job of hiding bobos. In this application a fairly thin coat would be all that is needed except for the inside floor which I will have done up to about .25 and fairly bumpy for non skid. Tar would be MUCH heavier. This done I don't plan on using any interior and an added advantage is that it should stop drumming.
Well none of you have convinced me - I'm sticking with my 2 pack paint job!
As for paint being heavy - well if it takes 1/2 litre to do all the panels - then the added weight is roughly 1/3 of the weight of the tin - as most
sprays into atmosphere and the additional lacquer etc.
So nothing not eating extra pies wouldn't solve
