Hi to you all.
After 2-3 years I'm still planning not building.
I need car with doors (and causally roof)
Does anybody know if CATERHAM 21 is build on same chassis -by the book?
Or where I can find chassis plans for FURY or STYLOS type of chassis.
Problem is chassis not the body .
The Caterham is not built to the Locost book design. It is very different in some areas and is generally much better.
The 21 and 21GTO were built on a stronger version of the Caterham design.
The strengthening consisted of adding extra tubes to the sides to make very large sills, shaped like big toblerones, along each side of the car.
