ive been working from the old book. but ive just bought the new book the chris gibbs one. am i right that this book gives you details in using the
sierra uprights. and does it use the same mounting points on the chassis as the old book.
adam
The chassis are different between the Ron Champion and Chris Gibbs book, so the Sierra upright details won't be directly transferable.
iam thinking about cutting the front of the chassis off. and redo the front section in a box to make the mounting points easyer. after all the nose
cone will cover it all up. and i no i could get it all with in 1/2mm like that.
adam
