Pinto to Zetec?
wydraz - 4/1/09 at 01:13 PM
Hi Guys,
Can someone with more knowledge than me (not hard!) list what it would take for a novice to swap out the exisiting 1988 donor sierra 2.0 OHC pinto (single weber carb) for a more modern 1.8 or 2.0 Zetec or Duratec engine?
All I know is I'd need new engine mounts??, a new bonnet and exhaust manifold as it exits on the other side? What else?
My car is a 2004 build Indy and has the donor gbox/diff too.
Thanks,
Dan
[Edited on 4/1/09 by wydraz]
cd.thomson - 4/1/09 at 01:46 PM
Hiya mate,
I've been looking into this myself recently.
For a duratec you'll also need a new bellhousing for your type 9, an ecu, rwd sump and water rail. There's possibly more.
big_wasa - 4/1/09 at 01:47 PM
Depends on the level you want to take it to.
you could get away with running your carb on the zetec with a basic esc dis ecu.
the 1.8 will come with a lower sump and waterpump that rotates the correct way.
you will be able to use your alternator with a pully from a later dohc sierra.
Electric fuel pump.
plus the bits you have said.
power ~115 bhp
take it up a levell.
2.0 zetec (silver top) 1.8l water pump. Lowered sump.
bike carbs or throttle bodies on custom manifold.
engine managment system.
plus the bits you have said and you are looking at ~165bhp
delboy - 4/1/09 at 02:03 PM
Dan, or for that matter anyone who's contemplating a change from pinto to zetec or bike engine. I'm looking for an exhaust manifold for a pinto to fit to my indy, preferably stainless steel, cash waiting.
[Edited on 4/1/09 by delboy]
mat.price - 4/1/09 at 02:10 PM
the a good article in januarys complete kitcar page 42 about pinto to zetec that has some good info
the only thing is dose not say is that exhaust on a zetec is on the other side to a pinto but it's a good read
kj - 4/1/09 at 03:03 PM
Hi seen the article, they guy who owns it is on here and sure he will help, kenf27.
bob - 4/1/09 at 03:38 PM
I did this year before last, plenty of work including all front loom changing sides because of exhaust but i must say well worth the effort.
Here is a good link re zetec needs.
zetec link
Plenty of pics in my archive
bob - 4/1/09 at 03:41 PM
Also just to add i had luck getting the 1800 silvertop free, the instal including megajolt blade carbs new plumbing clutch and tiger sump cost me nearly £1K but i managed to draw back £440 in pinto related parts i sold.
Xtreme Kermit - 4/1/09 at 04:33 PM
Had a think about this too, and the duratec is more appealing to me because of the exhaust being on the same side as the pinto.
bob - 4/1/09 at 04:39 PM
I did research the duratec but found it far cheaper to bolt straight onto the existing type9 gearbox, the exhaust will have to be replaced whatever side you exit on.
cryoman1965 - 4/1/09 at 10:15 PM
The exhaust from the Pinto will fit onto the Duratec with a bit of manipulating & heat. keith2lp from this site changed from a pinto to a duratec and used the same exhaust.
Nige
DavidW - 6/1/09 at 02:03 PM
Dan
I have one that I am about to sell. It's an MK one that came with my part built kit.
The engine was running with it installed but I don't think it drove anywhere. It's been stored for a while and whilst in good condition would benefit from a polish to look completely like new which is almost what it is.
Not sure what it's worth?
P.S. I'm now on the look out for a zetec manifold.
