Hi guys
Can anyone reomend what fuel line I need and where I can get this from? Also I have the delux kit from MK which has brake pipes set in but I guess i
will need further brake pipes will I? if so what spec and where is best to get these?
thanks
J
[Edited on 7/6/09 by EasyJimbo]
Anyone?
Depends what you got in your brake line kit from MK.
Usual fuel line is 8mm copper microbore heating tube + correct marked rubber pipe to suit your engine/fuel of choice.
You should have enough brake pipe to run your brake lines but it ultimately depends on how/where you route it. If you run out, have a word with MK.
With regards to your fuel line, you're better off measuring the existing fuel fittings on the engine/fuel pump and then getting some copper
microbore like Mr Balls says
Most good DIY places will sell it. You then need flexible fuel hose to connect each end.
Phil
