Indy R BEC to CEC
bodger - 15/12/09 at 04:27 PM
I'm toying with the idea of putting a Toyota 4age & T50 box in my Indy R. Does anyone know if this will work with the R chassis without too much hassle. I'm a bit worried about space in the tunnel. I'm under the impression the R was really designed for a BEC setup. Obviously will need to weld in some engine & gearbox supports but I don't want to have to chop the chassis up too much.
Is there any data online giving the dimensions of this engine & gearbox combo?
Please, no more BEC v CEC posts, it's been done to death.
fesycresy - 15/12/09 at 05:38 PM
Hasn't martyn16v (sp?) got an Indy R with a redtop ?
blakep82 - 15/12/09 at 05:57 PM
i'd have thought the basic chassis was the same, just with different engine mounting plates fitted?
Steve G - 15/12/09 at 07:56 PM
Some manufacturers widen the footwell area of the BEC chassis the tunnel doesn't need to accomodate a gearbox.
bodger - 15/12/09 at 08:18 PM
I've got a feeling this might be the case. Just waiting for MK to get back to me.
PAUL FISHER - 15/12/09 at 08:51 PM
There's no size difference between the bike engine chassis and the car engine chassis,the tunnels are the same,they are both built on the same jig,so most 4 cylinder car engines will fit in there no problem,you will just have to weld in additional engine and gearbox mountings for your car engine to fit.
blakep82 - 15/12/09 at 09:09 PM
hmm, i'd have thought it would have got a different name. you learn something every day
martyn_16v - 17/12/09 at 09:14 PM
Yes he does
The bulkhead on mine was put 3 inches further back than normal to get the engine back a reasonable amount. I don't think the tunnel is any wider than normal, it is a bloody tight fit on the type 9 (clearance on one side had to be provided with a lump hammer). It is a very early chassis though, I know there's been a few changes since so I have no idea what everyone elses will be like.
If I could find a picture showing how much clearance there is in the tunnel I'd post it. I'm sure I took loads...
