Hello Chaps
I am running a zetec 2.0 ltr Blacktop inMK and we are struggling to work out what rad to use that is small enough to fit but big enough to keep the
engine cool
the standard MK rad is £150 but we are hoping to get one cheaper that that
any advice would be great
thanks
Polo.
Nearly everyone uses the VW302 rad from a VW polo. Cost about £45.
Yep, 1.0 mk2 polo rad. fine for over 200hp in mine.
PS see yr in woodville, a local then!
I visit a chap in woodville fairly regularly, small world!
Polo or Micra rads both work are cheap and are well tested by builders
check ebay out I think GBS are selling the escort items for around 80 we have on running on a 2 litre silvertop no problems at all and it has seen a few track days
Polo as above or Golf one which is 30mm or so bigger if you're worried.
About £35 online, maybe less.
HTH,
James
[Edited on 9/3/10 by James]
I'm running a VW 302 as above.
about £35 (inc vat and post) for a mk2 polo rad from northern radiators
is it just me, or have there been a LOT more threads than normal about radiators the past few days?
thanks for the advice i will get one ordered.
Nice one
i used a mk2 escort rad, they are about the same price as a polo, and are the ones mk sell, but they blank the top cap off, but i did not want to run
a header tank so it was perfect for me.
stuart
