need a new throttle cable for mk indy running 2 litre zetec...the current one has been chopped down and has no nipples on either end....anyone know
where i could get one? or would i still have to chop down to give correct length?
gary
I recently bought a universal kit from thesse guys.
http://www.venhill.co.uk/Home
Top quality and good value.
HTH,
Matt
see above post the venhill ones come with all the ends you would ever need
Ive used bike brake cables for 3 years no problems
thanks guys......will have a look at what exactly is fitted on my car....then first port of call will be to attack one of the unused mountain bikes in the shed lol
think i solved my problem....the throttle was very jerky in its motion despite trying to lubricate....on closer inspection i noticed the route the cable took gave it 2 fairly tight turns so i re routed it along a much "friendlier" path and the whole thing is much more fluid in its motion......hopefully i can get the much needed smoother take offs instead of breaking my neck each time
