I'm at the stage where I'm mounting my gearbox and I need to lower it by about 1.5-2" relative to where it would sit if i used the
standard sierra mount.
Has anyone used the MK mount and can they tell me how far it lowers the gearbox? A photo would be ideal if possible
Pete
My problem is that if I mount the gearbox using the normal mount the alternator sits too far forward and fouls a chassis rail. If I drop the gearbox
then the alternator moves back just far enough to miss the rail.
Have you got any idea if I can get hold of a lowered mount from anywhere?
Pete
Pete,
I have the same issue with my Indy as well, but I am planning to make some spacer blocks to lower the mount by about 25mm. At the moment I've
got the mount on top of the plates in the tranny tunnel, but using the spacers I will monut it from below. This should drop it enough to help with
the alternator and also improve the angle at which the prop runs.
What have you done for an alternator and mounting bracket?
Nick
maybe i'm missing somethink here but i would have thought that you would want the prop shaft in as straight a line as possible
tony
What Snoopy says is, I think, best: mount the gearbox with the small crossmember that's already part of the gearbox assembly. Mount it on top of
the plates that MK have welded in place for this purpose.
Then buy and fit a small alternator from the likes of a Diahatsu Charade, around £35.00 from most scrappies.
If you lower the gearbox then you will have to raise the rise height of your car to get a decent ground clearance.
If you don't raise the ride height then you will be at risk of severe damage as the gearbox already sits around 20mm below the undeside of the
bottom chassis rail.
HTH
Originally posted by nick205
At the moment I've got the mount on top of the plates in the tranny tunnel, but using the spacers I will monut it from below.
Nick
