question for the bike engined owners, throttle pedal is great for trackdays but seems a bit harsh for road use.
I made the cable pickup point 2 1/4" ( 55mm ) from the pivot point, only takes about 40 mm of travel and the blade is on full power, what sort of
distances are you guys running from centre of pivot point to cable pickup
many thanks
tony
[Edited on 12/4/11 by mad-butcher]
I had to make a 2:1 reduction lever to give about 90mm pedal travel
