Cable stops
tantoelauw - 25/6/11 at 04:26 PM
Hello,
After I had received the correct clutch pedal, I was on my way again. I am wondering though what i can use for a cable stop. I can't find a suitable cable stop anywhere.
I needs to be some kind of plug or a cap maybe with a hole, in which the black cable is stopped but the actual clutch cable can run through.
Is there anyone who knows what i can use best to get the job done.
Greetings,
big_wasa - 25/6/11 at 04:59 PM
Its on the end of the clutch cable isnt it ?
tantoelauw - 25/6/11 at 05:23 PM
Hi,
No it's not at the end of the clutch cable, so i guess that would mean its not really a clutch cable. I think i will have to call my dealer again.
Where can i buy a mk indy clutch cable? Will any clutch cable do? I don't want to wait for the dealer to send me the correct parts again.
Greetings.
jacko - 25/6/11 at 05:28 PM
Give Hellfire a u2u as he is using the same engine as you in a MK indy
The photo above is of a type 9 gearbox clutch cable
Jacko
Davegtst - 25/6/11 at 07:59 PM
That tube on mine is for the accelerator cable. The clutch just had a hole (in the wrong place) in the bulkhead. How come your brake master cylinder only has one outlet?
jacko - 25/6/11 at 08:11 PM
The tube is for the clutch cable on my indy but my car has a car engine / box
Coopz - 25/6/11 at 09:46 PM
Talk to Mac1, they can supply top hats with a cable adjuster tapped into it correct size! works well I'm using one for my accelerator and clutch cable.
tantoelauw - 26/6/11 at 02:58 PM
Because I have 2 brake cilinders one for the brakes on the frontside and the other obviously for the brakes on the backside. Is that unusual? It was like that when i bought it.
Anyway thanks for the info everyone.
