Well fitted the rear diffuser and went out for a blat for the first time since fitting it and I have discovered that, even though the rear of he car
seems glued the road, the front end has becoming strangely light.
Hence my question is should I be doing something with the front end or suspension to compensate?
Splitter on the front will help...
there is a very interesting discussion about this on the RGB forum, they conclude that both splitter and diffuser are required,...
I hope to understand a little more after I have completed the recommended reading by a bloke called Katz,..
hth
Surprised to hear it's had such a dramatic effect. I always understood them to be a mostly cosmetic thing, and also helped prevent the parachute effect of the open rear end.
I saw similar comments on this very forum and assumed it was being made by someone who clearly did not understand that every little change has an
effect. I plan on adding both, the big question is how big a wing do I need on the front to balance it out.
My hope is not too large, otherwise I will tweak the diffuser to reduce it's effects. It's all a matter of balance.
Just added a splitter and aero'd front cycle wings to mine and it's noticibly better at the front - not necessarily any downforce production - it's just removed excess lift, and also funnels more air into my oil cooler. will try to get some pics. Steering is still weighty at unmentionable speeds. Which diffuser have you gone for? Did you put a flat floor on too? It's my next job to do.
This would do it...
Originally posted by Steve Hignett
This would do it...
My diffuser s ne from MK and butts right up against the floor pan, which is flat. I would no have thought it would have made tat much difference but it has, very surprisingly. My steering has never felt as light at speed how it does since fitting he diffuser..... If a splitter is he cure then that's the route I will take, but I intend to manufacture this myself so some pics would be nice....... Thanks for the replies everyone!
Will keep an eye on your progress as I want to fit a diffuser to my kit and fancied a solitude to go with it, do be interested in your results.
Have you panelled the underside of the engine bay? TBH, I find it rather surprising that you say you can notice the difference and seem to be
suggesting that it has increased downforce at the rear. Most discussions on here have concluded that fitting a diffuser does very little to the
aerodynamic performance of a seven. I'm sure there are people on here who have actually carried out wind tunnel testing on sevens fitted with
diffusers and have arrived at the same verdict......
Is your diffuser much different to other designs? Got any pictures?
Phil
[Edited on 14-5-12 by Hellfire]
http://www.locostbuilders.co.uk/viewthread.php?tid=168163
Don't know if you get track driver magazine but they love a splitter and it sounds like it may help. According to them they need to be quite thick and say 13mm ply is a good material to make then from. Apparently making one from a thin bit of ali or carbon is no good at all. Is under the engine bay panelled flat.
I panelled ender side f the engine bay last year, not realising what would do, it was to prevent road debris coming up into e engine bay, e car is vertically flat underneath......
