Haven been on here for a while so hi to all
just fitted a new rear diffuser to the back of the mk indy r
fits well and is nice and strong looks good
hope you like it
[Edited on 13/7/12 by raptor700]
That looks great, fits well, is it the mnr one, how have fix it underneath.
Details, details!!
interested too...details!!
Will it actually do anything?
Looks a bit deep to me. Shouldn't the back wheels be touching the ground?
Hi , yes it's an mnr one it's a little too wide for the Mk, so it has to sit slightly underneath the rear panel prob about 2cms
You get a metal strip that pop rivets to the floor and the diffuser slides in this, this holds the front up and it's bolted at each side inside
the rear wheel arches.
I had to cut some off the front prob about 10cm as I have a reverse box hanging down.
I took the pic just after I had fitted it so it's still jacked up !!!!!
The diffuser hangs about 1cm below the diff , it covers the fuel pump underneath the tank which makes it look better.
It took a lot of cutting here and there , round the rear arches, once the rear was bolted up at the other side of the rear wheel arches it was nearly
done but the centre was floppin a little so if the wind caught it could cause problems , I made a bracket and fibreglassed it to the inside of the
diffuser the riveted to the underneath of the rear boot panel
Am not sure it would do anything but the wind under the car comes out smoothly at the rear
I am getting the car out today so I will add some pics and see what u think
some more pics
sorry about the huge pics no idea what my comp is doing or why they are so big
That looks good Raptor. Does it box in the area under the rear axle completely to give a flat surface for the airflow ?
