GSXR sump clearance
Yellow Peril - 15/3/13 at 06:15 PM
I have recently bought a GSXR K3 powered MK Indy and am delighted with it. However, one issue/concern is the very low ground clearance to the sump plug. Anyone got any ideas or solutions that dont involve mega wonga or tractor tyres..?
Dopdog - 15/3/13 at 06:24 PM
how low is low?
Yellow Peril - 15/3/13 at 06:33 PM
It's not horrific...yet (I'll have to measure it). As a reference it currently just clears a low sleeping policeman, but I want to change the wheel/tyre combo from 205 40 R17's to 195 50 R15's and that will reduce clearance even more (10mm I think). I hear there are kits you can get to raise the sump or reduce it in size.
[Edited on 15/3/13 by Yellow Peril]
Dopdog - 15/3/13 at 06:53 PM
next question what sump is fitted at the moment? pictures are good
loony - 15/3/13 at 07:02 PM
Originally posted by Yellow Peril
I want to change the wheel/tyre combo from 205 40 R17's to 195 55 R15's and that will reduce clearance even more (10mm I think).
When you change wheel/tyre to 195/55R15 then wheel diameter will change about -0,3mm... so if you fit new tyres they will be larger than your actual setup with part used tyres (205/40R17) for few mm of "brand new" thread...
Yellow Peril - 15/3/13 at 07:25 PM
Yep I just realised I miss typed that the tyres I want are actually 195 50 R15's so about 20mm smaller dia. Will aim to take pics over weekend
Sloan85 - 15/3/13 at 09:04 PM
Keen to find out how much clearance you have got. Building a gsxr k1 indy at the minute and I can see the sump sticks well below the chassis and I've not got the wheels yet.
blowden86 - 18/3/13 at 09:51 PM
Same issue myself with a K3, only have about an inch and 1/2 of clearance off the ground on 15's. Cheapest solution I've found so far without bodging the current sump is to change to a swinging pick up sump. On Ebay for £500 Or if you're flush you could convert to a dry sump, expect £2K+. Not sure if adjusting the suspension will give me any additional clearance, will post here again once I've done some more research!
Dopdog - 19/3/13 at 07:10 AM
Are you guys using the standard sump?
Yellow Peril - 19/3/13 at 07:13 AM
Yes std sump on mine - not had a chance to take photos yet, but think I've got more than 1.5" though.. What Tyres have you got on your 15" wheels Blowden86 ?
blowden86 - 19/3/13 at 09:13 PM
I've got Toyo Proxies T1R's but as I mentioned as I'm still during build so the suspension may need adjusting. I've currently got 3 1/2 inches of clearance (to the chassis) at the front end and 6 inches at the back, not sure if that's standard but I'll be taking the car back to MK for final setup once I'm ready. Would appreciate any comments on general clearance to the chassis as that might solve the issue!
Yellow Peril - 19/3/13 at 09:22 PM
I checked out your build diary - impressive. From the photos of the wheels it looks like you've gone for 195 50 r15's which would give slightly reduced clearance compared to mine with the current 17" wheel/205 40 tyre combo I am running. I want to switch to 15" wheels with 195 55's which will give the same rolling diameter. 195 50's are my preference but the ground clearance issue is putting me off. We're virtually surrounded by blessed speed humps and cushions here. Just one more road and I won't be able to get out except on a trailer
blowden86 - 19/3/13 at 09:31 PM
Why thank you! It's in desperate need of an update but I prefer to spend the majority of my spare time working on the car opposed to being sat in front of the computer. However these cold dark nights are not the best time to be in the garage anyway!
Ah right sorry I didn't really answer your question about tyres then, but yes I expect you're right on the sizes. I'm mentally busy with work this week so won't get a chance to call up MK until Friday but once I've got some feedback I'll post it up here. Unless anyone beats me to it then I'll be interested to know!
And yes all the speed bumps are very worrying, especially with a BEC with electric reverse for attempting a 3 point turn when you come across one you don't dare attempt to cross...
Yellow Peril - 19/3/13 at 09:40 PM
I've no reverse..yet, but am now beginning to think it would come in handy. Plenty of folks say you just need to think and plan ahead but I'm not that forward thinking..
raptor700 - 24/3/13 at 09:37 PM
i have a gsxr 1000 k5 and have just bought a wet sump and swinging pickup
its a billet sump (well engineered) with a swinging pick up its £452 but if you ring up and pay by card then they dont have to pay the ebay fees think i got it for about £390 i also got a baffle plate to go in as i started doing track days
ebay item number 220999258112
The other option is to cut the piece thats hangin down on the sump and have it rewelded flush with the plug put back in you just need a good ally welder just need to check where and how far down the pick up goes its not the best but it will prob cost you about £30
if your doing track days then you will need to baffle it hope these help
blowden86 - 1/4/13 at 04:03 PM
Cheers raptor! I've since spoken to Danny at MK and they just shorten them and weld on a plate on the bottom. Apparently this only looses about 100ml of volume, and you'll make some of that back up with the additional piping where the oil cooler is relocated in front of the radiator.
I'm still being indecisive though, I won't be doing track days but I'll still be driving her pretty hard! The last thing I want to do is blow the engine with a modified sump due to oil starvation, so maybe the wet swinging pick up is the way forward. Now I just need to justify the cost in my head :S
Dopdog - 1/4/13 at 10:06 PM
I run a jedi with a flat sump and overfill the oil, we run them to 3000rpm and fill to the top of the sight glass. Question is do any of you guys over fill your oil?
Yellow Peril - 7/4/13 at 08:32 PM
So having finally had plenty of opportunity to get out and about this weekend I'm pleased to say I don't think the sump clearance (or lack of it) is going to present too big a problem as long as I manage to avoid speed cushions (those pads most of us straddle in standard cars). The clearance is about 110mm but it's not much behind the front wheels.
I've also been thinking a bit more about my wheel/tyre combo. The 205 40 r17's look fabulous [img] [/img]but the combination has a tendency to want to throw me into a field at each and every encounter of a stone, bump, pothole or any other surface inperfection.
I've got some 15" wheels I may swap over and put some 195 55 r 155 tyres on.
Any thoughts ? What rubber do you recommend I consider for spirited dry road use ? Are there any alternatives to Toyo Proxes TR1's ?
