Hey all, jus wondering if my mk exhaust is made wrong. When the connecting pipe is connected to the mani, and the box to the connector pipe, it
doesnt run parallel with the sidepanel. Instead it touches the angular bit below the scuttle line and sits way out.
Hope u understand that, i just about do
Jay,
Have a read of the link below. I got the manifold way (6 months or so) before I got the silencer, and by the time I did get the silencer the design
had changed. http://www.locostbuilders.co.uk/viewthread.php?tid=11789
Does your's look at all like that? The silencer/exhaust should not touch the GRP. Any chance you can take a pic of what's going on?
All the best
Ali
get on the phone to mk as i had the same problem and they had sent me the wrong piece the bit you have to cut has to be s shaped..they put it in the
post the same day.. cheers
[Edited on 19/4/05 by shed]
Cheers fellaz, will get a pic later and maybe call mk in the morning
here are the pix
