as title, bit stuck here really, i've still got my ignition barrel on the column mainly for getting through sva mechanical immobilisation thingy,
so i can't really just sleave it with some wide tubing but the sierra cowling is just totally the wrong size and as i have no stalks there looks
rather silly!
anyone help?
thanks
john
How about a piece of 4" plastic waste pipe? Bond some brackets on the inside to hold it in place, and a coat of paint or cover in vinyl.
I thought of using plastic piping myself but it was a complete pain in the a*se to get it around all the column mounted switches. If your switches are
dash mounted then it might be a lot easier and would look good if finished as zetec says.
Pete
