Just wondered where other choose to place the jack on their Indy?
Is there a 'best' place to jack the back and front?
Rich.
[Edited on 21/6/05 by shortie]
I use the diff at the rear, at the front I use the front cross member with some cardboard to protect the powder coating. I wasn't really sure
about the front but it doesn't seem to have done it any harm
Mark
Likewise, I use the diff at the rear and the front cross member immediately in front of the engine at the front. I use a thin bit of plywood to
protect the diff/chassis, but my trolley jack (Blue Point 2.5 ton) only just fits under the chassis rails.
I figured it's better to jack from a central point and raise the whole fron or rear, rather than jacking on a corner and risk twisting the
chassis unduly.
HTH
Nick
Thanks guys, will use the diff and the front chassis rail then as others have done.
Can also pass on a tip that I find handy. If you want to rest the car on something then the bulk packs of paper work a treat, I have two bulk boxes
and you just use the required number of pack on top of each other.
Hope that makes sense!
Rich.
intersting
I've got 2 pairs of axle stands
We've got half a dozen milk crates...........................
