Zetec SE Boyz - Alternator advise
seadog - 13/4/07 at 09:51 PM
Boyz,
Could you advise me on the alternator for the Zetec SE?
I have been told these are controlled via the Ford ECU therefore I will have to look at going for a third party alternator to get round this to enable it to work.
Is this the case???
Many Thanx
[Edited on 13/4/07 by seadog]
takumi - 14/4/07 at 07:50 AM
I am using a mini Denso alternator, as used on Kubota forklifts, it has 2 outputs one for ignition and one for charging light, and the main power output.
stig mills - 14/4/07 at 10:04 AM
SE unit is controlled by ECU. If you use it without they put out around 16 volts and destroy batteries quickly. I use donor ECU on the MEV Rocket more often than not, you then get passive anti theft system on your kit if you use donor key and barrel.
ned - 14/4/07 at 09:19 PM
He doesn't have the ecu, barrel or key.
dogman I may be able to help you out I have a cunning plan
seadog - 15/4/07 at 08:06 AM
Boyz,
Many Thanx for your advise.
[Edited on 15/4/07 by seadog]
