Ride height
RobH - 4/10/07 at 08:55 PM
Could someone clarify this for me please?
At what point on the chassis is the front and rear ride height measured?
Is it at the lower wishbone to chassis mounting points?
blakep82 - 4/10/07 at 09:01 PM
lowest part of the car (excluding wheels and tyres obviously ) to the ground isn't it?
Chippy - 4/10/07 at 09:37 PM
Ride height front is measured from the underside of the chassis, by the front wishbones. Rear is underside of the chassis, by the rear wishbones. If you mean ground clearance, then that is from the lowest part of the car, usualy the sump, or bell housing. Cheers Ray
RobH - 6/10/07 at 08:07 PM
Thanks Ray
Thats the kind of answer I was looking for.
I can get on and set the ride height now.
Thanks Rob
