I want to make up some dummy struts to see How the car will sit, can anyone measure front and rear length at normal ride height between the mounts
Bump anyone? Roughly?
I'm also interested, just found some 25mm box section & was planning on doing the same whilst I'm building, saves the expense of coil overs until later in the build.
I've set my rear now to 13" just so I can get some wheels on it to get it rolling, working on fronts at weekend
