The definitve donor?
DaveFJ - 16/5/03 at 12:00 PM
Ok so I know I'm going to get a huge backlash here but.......
For simplicity/ease/cost
what is the BEST donor for my planned Tiger Avon?
I'm currently thinking a 2l pinto sierra (non injection) about '88 - opinions please.............
[Edited on 16/5/03 by protofj]
Viper - 16/5/03 at 12:09 PM
That would be the one, any Pinto engine sierra with drum brakes and without injection is going to be the simplest build, changing the engine or rear brakes to discs is going to complicate things a little,
If you want an easy build perhaps the Avon is not the best option, don't know about the cat, haven't had any experiance with one.
Northy - 16/5/03 at 05:29 PM
To fit 2L rear drums on the rear uprights, you have to grind a couple of corners off. 1.6L ones are a little smaller = lighter, and fit straight on. Other than that, perfect!
I've had a few problems, but don't be put off, there are not many (if any) kits that just drop together
mok - 1/9/03 at 06:53 PM
Hi
I got a late -80 scorpio with 2l pinto inj.
what stuff could i use for the Avon?
rear axle has discs.
marshall - 2/9/03 at 09:50 PM
i am building the tiger avon and if i was you i woulddo the tiger e1 if i was you it is a better kit than the avon
marshall - 2/9/03 at 09:54 PM
i am building the tiger avon and if i was you i woulddo the tiger e1 if i was you it is a better kit than the avon Rescued attachment eng 04 s.JPG
