hi all
just a quick 1 is the correct offset for the Avon 35?
Someone are running et35, with 195/50r15 on the rear weel. I tryed et49,5 from 1995 mondeo on the rear weel with 205/55/15, it seems ok. But I only did a trial . I will retry to put bodywork (hope) within a pair of weeks an will let you know. I do not know if on the fron weel et49,5 is ok for you becouse I have sierra uprights .
Mine are et35 and fit just right.
I think mine was 35 or 38
Carl
if i remember correctly my offset is et 38
[Edited on 19/3/07 by tractorboy]
A photo : this tyre is 205/55r15, wheel is et49.5. Problem is find out an aly wheel et49.5, it seems the most common aftermarket aly wheels (ford 4
holes 15" is et35, et38, et 42
another
Sorry this means nothing, I did not want it on my post.
I ordered some compomotive 16x8 wheels for the rear with an et of 51 which should have been just right BUT... compomotive now say they can onlyt do
et35 max and i have already bought the 245/35 tyres.... so I guess I am going to have to extend my arches (I make it about 17mm to be comfy)
should look good in the end though
I think avon arch is already very big, so I would not extend it. Try to find out weel with the right et or have it done for you ( I saw europa spares catalog, and I remember someone can made weel , you have to teel them measure. I do not remember how much but it was not very expensive as you could think
I saearched for months trying to find 16" wheels that were available in both 7" and 8" widths. The only ones i came up with were the
compomotive MO's. when it came to ordering them the 7" can have an et38 no probs but the 8" have a max of et35 (if you want the six
spoke wheels it's et10 max!!).
I could have gone for 3 peice split rims but that would have cost twice as much and I have already spent £1100 wheels tyres so decided to go with it
and extend the arches. - gives me an opportunity to make them the same size at the same time!
Jusat as well i had already decided to spray the rear arches black.....
Sorry I do not have any advice
rudy, can you put a pic on here of the other rear arch with the wheel fitted pleased, and thanks for all the replies lads
I had all sorts of fun with offsets in the end i just widened the rears to fit,both arches are now the same
widthhttp://www.locostbuilders.co.uk/viewthread.php?tid=60772&page=2
[Edited on 12/4/07 by soggy 3]
Yes, I will. (maybe within a pair of day). However I found aly wheel 15*6 et 52, maybe I will buy it and within a week or two I will post new photo with thi kind of wheel.
another angle
another angle
thanks for that rudy, i got a et 42 in the end and it seems to fit about right, thanks again
I see yesterday the et 52 but I don't like the design, so in the end I will fit et 42 too. I find out a nice wheel, I will post a pair of photo with 195/55/15 and 205/55/15 when I will have the new aly wheel.
