There's a detailed article along the lines of the problem I'm having.
Article repair starts off...
"Honda uses very small o-rings to seal both the main jet and the float-valve body"
Its saying to uses Gaskets Sealer for the O -rings in the float chamber, doesn't specify the brand, but the relevant picture is captioned
"apply a very thin smear or silicon RTV"
The article then indicates to use this to seal the float chamber body
I was under the impression RTV wasn't fuel resistantproof
Does anyone out there know who is correct?
As a side point - I've already tried using the original gaskets with both Universal Blue and Loctite 5299 as a dressing (as both are Fuel
resistant) - neither have sealed the chambers
Gaskets are 2-6 weeks from Honda @ £31 each - hence the interest in the article
[Edited on 29/6/09 by skidude88]
