What to look for when inspecting ZX12 clutch?
eznfrank - 14/2/10 at 08:29 AM
I'm about to stick some Barnett clutch springs in the ZX12 and this will be the first time I've ever been anywhere near the clutch. I have no idea what condition it's in so what should I be looking out for?
I have had the engine running but not driven the car yet.
Steve Hignett - 14/2/10 at 08:38 AM
Do you have a pair/set of vernier calipers?
If so, then I'd suggest measuring the plates and compare to (haynes or other) book tolerances...
Obv. also check for discolouration and general W&T
eznfrank - 14/2/10 at 08:48 AM
Not got any verniers but have been meaning to get some anyway.
I'm hoping all will be ok as it's only done 2300 apparently.
RichardK - 14/2/10 at 09:16 AM
You got an Aldi nearby?
Linky thing
Rich
ReMan - 14/2/10 at 10:22 AM
As above friction plates within tolerance and plain plates glass flat and not gone blu/brown/black with heat
[Edited on 14/2/10 by ReMan]
eddbaz - 14/2/10 at 07:58 PM
Changing the springs is a five minute job Iwouldn't even bother checking the clutch plates,if the engines only done 2300.
Just fit the springs and make sure the clutch cable has a couple of mm of free movement and see how you.
