Attended my first TD in the new Mac#1 at Donny tonight and after just half a dozen laps was black flagged for 101DB drive by fail which meant the end
of my night's driving The limit is 98 so that meant 101 was twice as loud...??
Jonny has said I can come along for Thursday's session FOC, which is the final evening session this season.
So, I need to find ways of making the car quieter between now and then...
I was talking to a driver of an MK 'blade fitted with what looked like the identical exhaust can, he said he had been short shifting at 9K
through fear of the noise police. His car sounded fairly loud, as did many of the others there...
Anyway, do I need to just need to find a different can, and if so can you point in the right direction.
cant you fit a reducer in the end of the can, sometimes the induction roar is the problem as well. As said some just watch their revs at certain points where the noise police are sitting
not cheap but I had around 5 db reduction
link
I had cat fitted as well as a custom air box from .Mac1 and got the noise down to 101.
You won't get it much lower I don't think.
Some tracks are more lenient than others and look for loud days.
If you've got a bike can, search ebay for 'db killer' - I've known of them knocking off about 7db in a static noise test (with a
fair amount of exhaust wadding too, lol).
Originally posted by MikeRJ
No, 10dB is a doubling of perceived loudness, not 3dB.
You can get it as low as you want, bigger can, more baffles
An air box over the carbs
A quick fix is a baffle tube fitted in the connecting pipe
before the can, Rally Design
I have one of these for when very quiet is needed.
Not been measured, but almost too quiet!
You just need a flange-slip on adaptor also ebayable
http://cgi.ebay.co.uk/Suzuki-Bandit-1200-Exhaust-Can-/130423580842?pt=UK_Motorcycle_Parts
If the exhaust is to loud then you need a much bigger, diameter and length, straight through exhaust this will absorb more noise energy but not stop
the exhaust flow.
However you posted for a quick fix so decible insert is quick and cheap, engine may run richer and you will loose bhp
What snapper said is correct, I stock the Db killers, & have tried one in my exhaust & yes noticeably quieter, it will affect power but is a
cheap quick fix.
I haven't got them on the website yet but can do them for £9.95 + £2.95 P & P if it's any help?
the exhaust flow.
These work
Merlin
Motorsport
Thanks for the replies everyone
I'm not sure the dB killer will work with the silencer I have as that needs 210mm of straightish pipe after the can to work (I've been
reliably informed by Russ - thanks)
Is there a muffler which can be fitted to the end of the pipe?
[img]http://flic.kr/p/8vhSMZ[/img]
[Edited on 25/8/10 by bonesetter]
see above
Decided to go with a Db killer from Russ which he thinks will work, and if it doesn't I can fit fiberglass wool between it and the inside of the
tail pipe...
Fingers crossed
Decided to go with a Db killer from Russ which he thinks will work, and if it doesn't I can fit fiberglass wool between it and the inside of the tail pipe...
Fingers crossed
Agreed totally
I initially am after, and originally posted for, a quick fix for Thursday's evening session. I suppose I should have just gone for the larger can
option straight away as that would have taken as long to arrive as the dB Killer...
