R1 air intake size
jrrsparky - 31/12/10 at 01:20 PM
can anybody advise me on the ideal size of a flexable cold air intake hose for a R1 5pw
Major Stare - 31/12/10 at 01:35 PM
I have seen pipes from a front nose cone to an air box of 4".
What is your current airbox/filter configeration?
jrrsparky - 31/12/10 at 05:25 PM
Hi
It,s a standard R1 air box & filter
bassett - 1/1/11 at 04:10 PM
I'd say anything above 2" as the standard intake is a tiny rectangle.
matt_gsxr - 1/1/11 at 05:46 PM
I have 1 meter of 3inch diameter and get no pressure drop. gsxr1100, but similar air consumption.
previous thread on this here:
http://www.locostbuilders.co.uk/viewthread.php?tid=124753
Matt
bassett - 1/1/11 at 06:53 PM
follow up question, wheres the cheapest place to get ducting as with a sausage filter i should probably look to do the same.
jrrsparky - 1/1/11 at 09:59 PM
Thanks all for the info & the link ( I did a search but like others it has never worked properly for me )
I,v settled for a 75mm smooth bore hose
matt_gsxr - 2/1/11 at 11:08 PM
Searching is a pain.
Best if you can remember who was involved with the thread and a word in my experience.
Some folk use google, but tell it the site name (its an option in the advanced search), which seems to work well.
I vaguely remember being told to put % around words in the LCB search, if you don't and you have multiple words then it looks for it as a phrase.
75mm will do the job nicely.
E-bay isn't too expensive for this kind of stuff, as it is proper Saxo / Max Power sort of stuff.
Matt
Yazza54 - 3/1/11 at 03:45 PM
Where can you buy smooth ducting??
I have superflex which is decent quality stuff, but surely as an air intake it is better not to have all the ripples in??
charlie_pank - 5/1/11 at 03:34 PM
Surely only 1 cylinder is sucking at a time, so the cross-sectional surface area of the plenum opening doesn't need to be any wider than one of the throttle bodies?
