Poached from blatchat - http://www.blatchat.com/t.asp?id=199854
Its exactly what you learn on a bike, load the lever with your foot, then nick the throttle off and then back on - as you do that the gear snicks in
sweetly.
Interesting what he said about cables...
How easy is that technique with paddles? Never used them.
It works lovely with my gear lever, rose joint set up.
Works just the same with paddles. Presure on the paddle and then lift the throttle and in it goes.
How about with Kliktronic?
I take it this is when pushing on, and at low speed/cruising a normal synchro type change is OK?
[Edited on 2-3-11 by 40inches]
