I want to shorten my Hayabusa sump, albeit by a fairly small amount (25 mm 'ish), but at the same time would it be best to enlarge it to increase
the capacity, and what type of baffle plate would be best to use? There are a couple of types out there, ie flat plates, the type that Extreme sell
etc. I am running an accusump also.
Any thoughts or advice would be most welcome
Cheers, Nick
Thoughts or advice? GET IT BLOODY FINISHED!!!!!!!!!!!!
Why spoil a good thing?
Cheers, Nick
Originally posted by iiyama
Thoughts or advice? GET IT BLOODY FINISHED!!!!!!!!!!!!![]()
hi nick
if i was you id spend the extra money and fit a billet sump with swinging pickup
thanks danny
Hi Danny, Icould do but I would have to modify the chassis rail to do so on my car, and that would be a PITA!
Cheers, Nick
I Been told all sorts on hayabusa sumps I was led to believe that a dry sump was the only safe setup ??? What do you have on your race car Danny ??
Don't believe everything you are told
Dry sump is not the only safe way to go. (Actually, dry sumps have failed on these and other engines).
There are a few people that run these with turbo power and slicks that have had no problem, HOWEVER they have kept the sump as per standard so that
you have full capacity. The only problem with this, is that it decreases the ground clearance.
Cheers, Nick
