I keep taking my Busa powered Indy out and finding that the clutch bite point is changing, sometimes leaving me stuck in gear and having to adjust my
pedal travel at the side of the road to compensate. The clutch used to be very snappy and close to the start of the pedal travel but now i find i have
to push the clutch pedal more and more to change down through the gears.
I'm due to fully check the hydraulics involved in pushing the clutch pin to see if the cylinder seals are leaking for example, but what if that
isn't it? I also plan on marking the clutch pin at the start of the drive and comparing it at the end to see if it's the pin which has to go
into the engine more to free to clutch or whether it's a case of an inefficient hydraulic slave and master clutch system. But what else could it
be? Degraded oil? Clutch plates? A crack slowly propagating somewhere? Advice much appreciated!
bleed it thoroughly and it will feel ok
if theres no sign of fluids it shouldnt be leaking
my megabusa requires bleeding bout twice a year - bled it once and the colour of the fluid had a black / grey tint... weird
you can alter the pedal feel too by moving the push rod that goes off the pedal to the master cylinder - move it and the pedals pivot point closer
together or further apart - closer will make it feel softer, less snappy
Could be a hydraulic problem but another option is a worn clutch basket. When they wear they develop grooves around them and the plates then stick in the grooves. When mine wore I found it made the clutch bite point very sharp and much easier to stall.
