getting ready to start my engine up.
should I be running fully synthetic 10-40 or semi synthetic 10-40?
I got one reply that said semi synth and one reply that said fully synth and one that said ask on here
i really dont mind which, but as I dont understand the difference (I do know suzuki recommend semi synth, but thats in a bike) in the two, I just want
to buy some
[Edited on 23/4/12 by MikeFellows]
just found this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=88485
Apologies
That link just tells you what they run.
If using an old clutch you may want to stick with the oil type that this ran in, either semi or full or you may experience slipping issues.
If a new clutch then just pick your prefered choice
For myself I run semi oil but do change it every track day as my turbo blade does turn it much darker after a hammering.
I used Silkolene Pro4 15W-50 in my Busa and still use it in my ZX10. It's what Radical use in their Busa engines. I use the 15W-50 to try to maintain pressure when it's hot but if it was a road car I'd use the standard 10W-40.
