Well,
We're just about ready to offer the RFalcon (end of month). We will offer the standard forward/reverse and an optional overdrive version. A
well-know bike engine car manufacturer in the states has one of our units in hand to test and may pick up several units from us test pending.
I've made several design changes to accommodate this manufacturer. We still are using the carbon-fiber /kelvar cover but will use the 6061 alum
instead of the cast A356; down the road we may switch back though to reduce overall cost.
* Carbon-Fiber/Kevlar cover
* 6061 Alum billet bearing housing
* Oil drain plug moved from the bottom of the carbon fiber to the side 6061 bearing housing plate.
* Tighten up the gearing center distance by 2mm to remove slack/backlash
* Slight mod to the mounting points
Website is up and configured to take orders in the US but I'm still figuring out the international shipping, VAT and handling . Again,
we'll officially take orders at end of month if nothing major pops up..
Its been a long hard road to this point.
Ryan
[Edited on 8/6/14 by yahshuatwo]
Good luck with this, theres defiantly a gap that could still be filled with the right product qualty at the right price
We're taking order in July, will have couple available to start. We will not keep many in stock until demand picks up.
