So on Saturday I had a little off in my Indy, low speed hitting the kerb with the NS front wheel, bending the wishbone and snapping the coilover, at
the time I was in first gear but for some reason now I can't select 1st gear, I can get every other but 1st.
There is no damage to anything else under the car and the select rod is fine.
Does anyone know what might be wrong?
