How much power does a quaife reverse gearbox use on a typical 1000 cc bec? been told its 30 bhp which seems like a lot.
Would be percentage not an exact figure - ie if you put 30 bhp in it wouldnt give 0 out.
Website states its 'straight through' to minimise power loss. I suspect its a fairly minimal loss. So any major losses would only be when
its in reverse.
[Edited on 16-11-16 by loggyboy]
A friend of mine dynoed a 6bhp loss on an R1.
quote:]
In our experience you can expect between 6 and 12 bhp depending on the condition of the box. For some strange reason the box is direct drive in
reverse which makes it far smoother and more efficient when going backwards.
Regards
Originally posted by Andy B
In our experience you can expect between 6 and 12 bhp depending on the condition of the box. For some strange reason the box is direct drive in reverse which makes it far smoother and more efficient when going backwards.
Regards
What were the 2 max power figures?
Wow 30hp!
But even 6 sounds a lot!
Assuming the MNR is similar there's not a lot of resistance by hand. I'd expect to take some and worse so at higher revs, but 6 still seems
a lot
Originally posted by ReMan
Wow 30hp!
Assuming the MNR is similar there's not a lot of resistance by hand. I'd expect to take some and worse so at higher revs, but 6 still seems a lot![]()
Regards
If it was direct drive, then the output shaft would not be reversed, literally by definition. Was this maybe a case of having the wrong diff or something and requiring a reverse to get forward motion?
