Hi, has anyone idea's??
my Honda clutch doesn't work properly.
i have tried a car (2) servo master cilinders
but it doesn't do the trick.
I also tried a 49,99cc brake cilinder but didn't work out.
Today i took off all the parts seems that my slave cilinder moves +/- 10mm max.
has anyone idea how much movement is needed for a honda clutch?? (hydro)
i used a wrench (long piece of metal wich u use to put big force on something)
to move the axle and it did move the basket but i wasn't able to rotate axle in gear...seams the clutch plates stick???
any one ideas??
TKS
[Edited on 28/3/05 by tks]
Are the plates damaged/twisted?
This may seem a bit odd but why not use the original honda Master cylinder ? suitably mounted with a push rod from your clutch pedal . look at how
much travel is needed and work out your pedal ratio to suit .
best wishes
Iain
soo what do we advice??
overhaul the basket???
or try a medium size M/C ???
TKS
the original M/c i don't have else it was offcourse eaten meat....
(peanuts)
[Edited on 29/3/05 by tks]
Just chec the cultch first then if needed, replace springs and plates, if not, new cylinder.
Checking costs nowt!
