R1 Exhaust Manifold for Locost
ChrisS - 19/9/05 at 12:30 PM
Hi
Can anyone advise where is the best place to buy an exhaust manifold for an R1 Locost.
Im looking for an equal length spec manifold and do have a tight budget.
Many Thanks
ChrisS
http://www.kitcars-forsale.com
Hellfire - 19/9/05 at 12:44 PM
MK! Well tried, well tested, well experienced and well proven... £300-£400 but call or email to confirm.
http://www.mkengineering.co.uk
[Edited on 19-9-05 by Hellfire]
smart51 - 19/9/05 at 12:50 PM
MNR. www.mnrltd.co.uk
kingr - 19/9/05 at 02:26 PM
Or build your own, like this -
exhaust - tasty
exhaust - tasty
kingr
[Edited on 19/9/05 by kingr]
kingr - 19/9/05 at 02:36 PM
exhaust 2
exhaust 2
Mad Dave - 19/9/05 at 02:44 PM
Kingr - I'm impressed!!!
kingr - 19/9/05 at 03:02 PM
Cheers Dave!
mike-ktm - 19/9/05 at 04:13 PM
kingr, where did you buy all the suff to do that ? Really nice job. How much did it cost you to do, how did you work out equal lengths, bends etc.
Mike
kingr - 19/9/05 at 04:36 PM
I bought the mandrel bends and straight from a milking equipment supply company (Hygenic Process Equipment if I remember correct). Came to somewhere under £100, and I bought about 3 or 4 too many ells! It's all in 316L, so it's top quality stainless.
The collector and link pipe (not shown) were bought from an exhaust parts company (Custom Chrome, again, if I remember correctly).
I drafted out the pipe routing by using bits of brake pipe (all the same length) bolted to the block and bent to the correct radius using a template. I then built up each header by working from the manifold, carefully tacking up the sections of pipe, using the brake pipe sections as templates.
Took me far less time than I expected - probably about a weekend and a couple of evenings.
It's covered over 2500 miles so far, and no sign of any cracks yet.
Kingr
mike-ktm - 19/9/05 at 04:41 PM
mig or tig weld ?
did you just make them all to suit the longest pipe (eg most forward cylinder) ?
Mike
P.S. any websites for the companies ?
marc n - 19/9/05 at 07:32 PM
the gains you get with equal or near equal primarys is quite impressive especially if you go 4 - 2 -1 we have gained in back to back test 5 hp over a 4 -1 manifold on a blade and 7hp on an r1 all tests done on the same day at the same rolling road who incidently i would recommend to all in the yorkshire area Alwyn Kershaws just near elvington
mike-ktm - 19/9/05 at 08:15 PM
further to my earlier questions kingr, what size pipe did you use ? 1.5" ?
How did you do the section which bolts to the head ?
Mike
kingr - 20/9/05 at 10:17 AM
Cheers for the comments guys.
Yes, I used 1.5" tube. 2.5" for the link pipe, reducing (very slightly) to 65mm (or whatever the weird metric size of the R1 end can inlet is).
I had an old manifold for an R1, so I cut the manifold end bits and retainers off that and used them as the first section. If I'd had access to a lathe, I'd probably have machined them.
I TIG welded them (well, I had to justify buying my nice TIG set somehow !) with 316L filler. I believe that MIG may produce a slightly brittle weld, but I could be wrong.
I laid out the most forward tube first which dictated where the collector would go.
Kingr
